Transmission
Old Feb 8, 2014 | 11:13 AM
dglad's Avatar
dglad
Default Transmission
Hello forum could anyone tell me if a trans from a 95 lt1 camaro is a direct fit for a 95 vette?
Old Feb 8, 2014 | 11:18 AM
LTxDave's Avatar
LTxDave
No, the tailshaft housing is different.
Old Feb 8, 2014 | 11:56 AM
dglad's Avatar
dglad
Is the tail shaft interchangeable?
Old Feb 8, 2014 | 02:26 PM
383vett's Avatar
383vett
easily.
383vett's Avatar
383vett
easily
Old Feb 8, 2014 | 03:59 PM
dglad's Avatar
dglad
Originally Posted by 383vett
easily
Ok so I can use the trans out of the camaro just change the tail shafts out correct
Old Feb 8, 2014 | 06:11 PM
383vett's Avatar
383vett
You'll have to cut 5/8" off the output shaft with a cut off wheel (done that).
Old Feb 8, 2014 | 06:31 PM
mtwoolford's Avatar
mtwoolford
also need:
fbody bellhousing
fbody flywheel
fbody clutch
Old Feb 8, 2014 | 06:52 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by mtwoolford
also need:
fbody bellhousing
fbody flywheel
fbody clutch
I believe it was assumed the OP has a 4L60E and he had asked not long ago about the similarities for the A4.
To Transmission
