VATS-Help!!
Old Jul 13, 2002 | 09:01 PM
STREETKNIGHT's Avatar
STREETKNIGHT
St. Jude Donor '03-'04-'05-'06-'07
Default VATS-Help!!
Has anyone ever seen the plug that the bypass plugs into?
The installation sheet is fairly simple and straightforward but I can't identify the plug.
Any help would be greatly appreciated.
Old Jul 13, 2002 | 09:28 PM
HG's Avatar
HG
Default Re: VATS-Help!! (STREETKNIGHT)
My 88 had the Mid America switch already installed. I still have the original directions, so if this helps. Locate the small Black VATS connectors near the steering column. The female has two Black wires coming from the ignition switch. The male has one Brown and Yellow wire coming from the VATS. :eek:
Old Jul 14, 2002 | 11:55 PM
STREETKNIGHT
Default Re: VATS-Help!! (HG)
Found it, thanks for the direction. :cheers: :flag
To VATS-Help!!
