Steering column diagram
Old Feb 14, 2014 | 02:45 AM
1984gaboy's Avatar
1984gaboy
Default Steering column diagram
Does anyone have a complete breakdown part by part of a early c4 steering column. Put mine back together and something isnt quite right. I dont have a fsm yet and needing one terribly for my 84. If anyone has a schematic they could send me via email that would be great. thank you!
Old Feb 14, 2014 | 06:20 AM
WVZR-1's Avatar
WVZR-1
Did you only have the upper telescoping aspect apart?
http://www.steeringcolumnservices.co...copic&c=6006tt
The drop down link for the "upper" doesn't seem to "stick" so just use the "search again" & "drop-downs" and then select "telescopic-upper" to see just that aspect.
Old Feb 14, 2014 | 06:44 AM
1984gaboy's Avatar
1984gaboy
basically. I had to replace the lock cylinder. in the process i broke the u clip that holds that shaft from pulling completely out and had to fab up a piece for it. There was also a plastic thing that shattered when removed and a washer i left out. Thats why i need the diagram too see where the broken pieces actually go.
Old Feb 14, 2014 | 06:52 AM
WVZR-1's Avatar
WVZR-1
The two pieces you broke are likely the first two pieces in this link:
http://www.steeringcolumnservices.co...opic-parts.php
"Agent86" posted this some time ago and it's from the FSM.
http://dankai.shawwebspace.ca/asset/...ing_column.pdf
Just use the search term - telescopic - in the C4 section only and you should find several good reads.
Here try this:
http://forums.corvetteforum.com/sear...4&pp=25&page=2
To Steering column diagram
