86 Brake Problem
Old Feb 17, 2014 | 10:03 PM
Herdnation1's Avatar
Herdnation1
4th Gear
Default 86 Brake Problem
The drivers side front brake isn't working right or isn't working at all. I installed a new caliper new flex hose and bled the brakes, still very little brake fluid when bleeding that side. Could it be a crushed or clogged brake line? I also flushed the system brake fluid.i can still drive the car but it pulls to the right side.
Old Feb 18, 2014 | 01:29 AM
Cliff Harris's Avatar
Cliff Harris
A while back someone posted a thread on the gunk he found in his ABS controller. It was causing one of his calipers to hang up. He fixed it by disconnecting the brake lines at the controller and blowing air through it.
