Loud Vette
Old Feb 18, 2014 | 10:33 PM
easyriderfi's Avatar
easyriderfi
Default Loud Vette
Hi everyone
I have a 1992 LT1 C4 which I bought used. It has shorty headers, stock mufflers wit no cats from previous owner. I wanted more sound so I installed a set of muffler eliminators and this car may have just became a little too loud. idle is very calm and when coasting at 70 is calm but if I touch that gas BOY she awakes.
I don't mind the outside noise, it sounds good but its a lot to deal with on the inside. i'm looking for answers to calm it down a little. Wondering if I should install cats? I do want to keep my eliminators.
BWB
Old Feb 19, 2014 | 04:33 AM
Tapio@FTTRacing's Avatar
Tapio@FTTRacing
It will get more quiet if you install cats. Worth trying! I have melrose long tubes, 3" metal cats, stock resonator modified to be muffler and muffler eliminators at back. Quiet enough to drive looong trips without getting annoyed. And no drone!
Old Feb 19, 2014 | 06:58 AM
cohocarl's Avatar
cohocarl
Originally Posted by easyriderfi
It has shorty headers, stock mufflers wit no cats from previous owner..... installed a set of muffler eliminators...
Ya, I would think that would wake the neighbors.
I had stock manifolds, straight duals, no cat with Hooker Aerochamber mufflers on my 85 and it was very loud. Very nice, low frequency sound, but loud. (not like the annoying "crackle" noise of straight piped pee-cup trucks that leave the bar a couple miles down the road at 2:30am)
I was very happy with the sound, but thought I should try to tone it down a little, and try to reduce some of the drone. Last summer I added a couple low cost resonators (glass packs) from Summit and welded them on. They come in all different lengths/sizes, and I bought the shortest ones (12" body I think). It did tone it down, but not quite as much as I thought it would. If I had to do over, I would get resonators with a longer body.
Jones makes many other sizes than what Summit lists, but I they may be able to get the other sizes in. For an inexpensive glass pack, I'd give them a 9/10. I was expecting difficult to weld thin gage metal, but they are very stout.
Old Feb 19, 2014 | 08:23 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I have no mufflers but do have the cats and it works out just right. Get a lot of compliments on the sound.
Old Feb 19, 2014 | 10:17 AM
DanielRicany's Avatar
DanielRicany
If you put the cats back on you will probably lose some power.
I recommend you find a cheap but good muffler like Flowmaster or Dynomax and sell the eliminators so you don't lose power.
My L98 has Long Tube headers, gutted cat and 2 Dynomax Ultra Flo mufflers, with a flat tappet ZZ409 camshaft that also contributes to sound, but it sounds awesome. Loud, but not too loud.
Old Feb 19, 2014 | 10:31 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
straight thru high flow.
Old Feb 19, 2014 | 10:50 AM
WW7's Avatar
WW7
This is the same setup I have, headers, cats, muffler eliminators, this is the best sound I have heard, and I get compliments on the sound of the car all the time......WW
Old Feb 19, 2014 | 11:15 AM
eatmydst1234's Avatar
eatmydst1234
Flowmaster mufflers are over rated, more times than not create drone, especially in our cars.
I bet you would benefit ditching that single cat exhaust and running a dual exhaust back to your ultra flows.
On my otherwise stock LT1 car I ran muffler elims and loved the sound, I had no resonator on the car and little did I know the cats were empty too. It was just too loud to live with. I would almost bet with some cats it would have been perfect.
Old Feb 19, 2014 | 11:20 AM
Daytona69's Avatar
Daytona69
Same here...cats with eliminators and it sounds great
Old Feb 19, 2014 | 11:21 AM
DanielRicany
I am going to put a converted LT1 exhaust system on later on, I have a dynomax full true dual exhaust laying around the shop that I had on, but I felt more power with the stock exhaust so that's why I put it back on.
Plus, Dynomax is also a lot of drone, so was my straight pipes. If you don't want drone you gotta go with Corsa. I can deal with the drone.
Old Feb 19, 2014 | 11:23 AM
MavsAK's Avatar
MavsAK
Borla Mufflers. Problem solved
Or maybe OBX Mufflers those sound pretty good too.
Old Feb 19, 2014 | 11:48 AM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Still have the stock set up cats/resonator mufflers eliminated on my LT4 sounds great no drone.
Old Feb 19, 2014 | 05:02 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Magnaflo makes a great metal substrait CAT.
Or the ceramic is fine.
Both provide very minimal flow restriction and will "smooth out" the exhaust and dampen it a bit.
This should provide the sound your looking for.
Plus the smell from behind will be much better.
Old Feb 19, 2014 | 07:11 PM
c4cruiser's Avatar
c4cruiser
Factory LT1 cats flow very well and re-installing them may only cost 2-3 HP. The OEM exhaust from the manifolds to the center resonator is 2-3/4" in diameter so there is very good flow. Also with the stock LT1 exhaust, the factory mufflers don't really quiet the exhaust that much. Between the cats and the resonator (which is a fairly long open X-pipe) and the larger pipe diameter, most of the noise has been dampened by the time the exhaust gasses and sound hit the mufflers.
Flowmasters like the Super 44's or even the 40 Series are probably the worst for interior resonance. Some people have also reported that the Flowmasters will have more backpressure than mufflers like the DynoMax and may cause a slight loss of power.
I use DynoMax race mufflers on my '87 with Hedman longtubes, true duals, and an X-pipe located about 10" past the collectors. There is very little noise and no drone at all at cruising speeds. Even at WOT, I really don't hear a lot of interior noise. But at one area track that uses microphones for checking noise limits, the car has been read at 101 dB (3rd gear, WOT at 5500 RPM).
Old Feb 19, 2014 | 09:47 PM
eatmydst1234
i disagree with you on that. My car currently has the factory LT1 exhaust on it.. while i'm sure the resonator quiets it down some it os far too quiet for it to be anything but the mufflers.. My car has no cats to quiet anything down
Old Feb 19, 2014 | 10:32 PM
Klyde's Avatar
Klyde
I saw an LT1 resonator cut in half and it consisted of two pipes with holes the entire length wrapped in sound deadening material inside of a single enclosure. So the labeled "Dual Exhaust" on an LT1 is not a true dual exhaust. I guess the resonator could be considered a cross pipe of some sort. It most likely does reduce the noise level considerably.
Old Feb 20, 2014 | 08:19 AM
eatmydst1234
It does reduce sound, just not as much as you think. That's why a lot of people do muffler elims and leave the res in place. It quiets thing some, but gets rid of resonance, hence the name. The reality of it is, the cats quiet more than the resonator.
Old Feb 21, 2014 | 09:39 AM
volkswagens-for-life's Avatar
have a video? l98?
To Loud Vette
