I have an 85 I'm playing with with a four speed. Does anybody know where I can find a good replacement shifter for this sloppy 4+3 factory piece o junk that's on here? Can't seem to find any aftermarket shifters for it. Or any ideas how to spruce this one up..... Thanks
Typical of all external linkage shifters.
Start by checking the bushes on the linkages to the trans; most likely flogged out from age
i had to weld up and redrill the holes in the trans linkages that were worn oval
There were never any because the shifter is mounted to the trans tunnel ; not to the trans as is typical with other ext setups
I'll check the holes but if I find what you did I would be inclined to find some small bronze bushings to fit ths trans levers with...
