Electric water pump
Old Feb 21, 2014 | 06:36 PM
vetteOnTheRun's Avatar
vetteOnTheRun
Default Electric water pump
Anyone using an electric water pump for their daily driver or somewhat of a daily driver. If so, any problems? I have noticed when people replace them on their track cars they seem to rev just a little quicker than with the mechanical water pump. I'm thinking about putting one on my 93 thats not really a daily driver, maybe a couple times a week. Please dime in. Thanks
Old Feb 22, 2014 | 07:18 AM
vetteOnTheRun
No electric water pump users?
Old Feb 22, 2014 | 10:19 AM
Paul Workman's Avatar
Paul Workman
We've a few ZR-1 pilots using them, or used to.
On a 500+ hp LT5 they're worth around 12+ hp; maybe a little less on a SBC, would just be a guess. Also, the LT5 mechanical pump goes into cavitation around 5500 rpm and over. So, for sustained track use above 5500, there is some concern for overheating, which is addressed by switching to the electric pump.
Electric pumps may not be as reliable as the mechanical pumps. They have been known to quit all together or blow a fuse and quit, etc. (Locally one of our FBI gang had his pump go out w/o warning, except the heat gauge pegged. He cooked that LT5's sleeves. Fortunately, he was able to find some NOS replacements with the nikasil linings.)
So, although I like the idea of cheap hp, the vision of an electric pump dying while on the road, and not being able to grab one at the local NAPA, or the like, gives me pause. FURTHERMORE, I would want to install some type of monitoring circuitry to tell me when the pump had quit, other than the over temp light coming on (to tell me why the motor is now crap). Some sort of electric current monitoring device, methinks...
Reliability is THEE issue. In my experience, mechanical pumps are, by comparison, MUCH more reliable than electric pumps. However, if the use is limited to short drives and track events, especially if it is rigged to where there is constant monitoring, then by all means the electric would be a serious consideration. 99.9% of my driving is on the street/highways. For me, the mechanical pump stays.
Your mileage may vary.
P.
Old Feb 22, 2014 | 10:29 AM
vetteOnTheRun
P.
Thanks Paul.
Old Feb 22, 2014 | 11:57 AM
383vett's Avatar
383vett
I use one. The motor cools down in seconds between rounds.
Old Feb 22, 2014 | 12:42 PM
littlesk8cracker's Avatar
littlesk8cracker
been using one on my 94 for about 3 years now, works great. had to replace the little relay that was used in the wiring kit I bought but it was maybe $2, and that wasn't a problem with the pump, just the cheap relay
Old Feb 22, 2014 | 01:19 PM
Dt86's Avatar
Dt86
I like the idea but I'd be worried about a problem with one. If it fails how would you know besides cooking your motor? At least if you lose a belt, you know it.
Old Feb 22, 2014 | 09:17 PM
383vett's Avatar
383vett
Just wire it carefully and use a Bosch relay.
Old Feb 22, 2014 | 09:19 PM
vetteOnTheRun
I might try it. Again I will only be driving it a couple days a week may be 3 days a week tops. I also constantly check my gauges. I habit that I developed when I had to drive some real buckets when I was younger. Lol
To Electric water pump
