hey guys, When I pull real hard on the car and hit redline or close to it, i lose all throttle response. The car pulls great until i lay off the throttle and shift then i stomp back on the throttle and nothing. I still get resistance from the throttle but it feels almost like its stalled out but it is still running. I get nothing until the RPMs run down and then bam the engine is back to life like nothing happened. What could this possibly be?
What year car is this? What engine is in it? What RPM are you going to? I mean come on dude give us something to work with. I own a vette. It screws up. Help me!!! Really? We need more.
the ECM has a rev limiter built in and shuts of power to the engine at a set RPM. and please learn how to shift and drive. shifting that high you done went past the max torque and hp
Maybe it does and maybe it doesn't. It depends on the year.
My ECM has the rev limiter set to 10,031 RPM (it's effectively disabled). When I first calculated the number I thought I made a mistake. I did some research online and that is indeed the correct number.
GM would never warntey such a SB at that rpm and not when the red line is below 5K
This. The year of your car is needed to help figure out what you are seeing.
The LT1powered C4's have a fuel cutoff at 5850 RPM. When you hit that point, the engine will start to miss and RPM's won't climb after that. With the L98 motors, there is a limit when the stock TPI just won't flow any more air. That is typically seen at somewhere around 5000-5200 RPM.
Sorry guys!
It is a 94, Rebuilt LT1 355. Its got a ton of modifications
wow, I had no idea. I am relatively new to corvettes. So why is there a fuel cutoff when there is also a rev limiter. I've bounced off the limiter a few times and it seems higher than 5850 rpm and It was never accompanied with the shut off. I take the vette so far up the RPM because with the way it is set up and rebuilt its strong enough to safely extend the reline and the power just never drops off like it does in all my other experiences with other cars. In my other cars roughly 500rpm before redline I can feel the torque drop off and i've learned to shift right before that so hitting the limiter was seldom done and certainly no fuel shut off was ever experienced. Since the corvette never drops power I don't have that mechanical queue and sift at lower RPM. Maybe I need a different cam... or bite the bullet and get the car tuned raising the factory limitations.
When i rebuilt the bottom end I made sure to get nothing but the strongest of the aftermarket world.
Maybe I should get a shift light until I learn the feel, pitch, and sound of my engine.
like I said GM had to warranty these engines for so many miles and years. they did not want a bunch of these cars coming back for blown engines so they put fail safe features such as a fuel shut off and a rev limiter. I thought only simple kids in rice rockets thought its fun to bounce off the rev limiter
lol, dude i come from a long racing background (for my age lol). It all started with a go-ped at age 8. Started racing when I was 12 with shifter karts, then got into 2 stroke dirt bikes, quads, eventually got into super sport motorcycles (07 zx6r, then 2010 Yama R1) all my cars before now were v6's. If you didn't notice everything i just listed are high revving platforms.
So i've got 19 years, worth of reving to the last possible RPM before shifting, to revise. playing chicken with the redline is part of the skill set when racing vehicles that only have torque up high. so take it easy on me lol
I'm 26 man. I am probably younger than 95% of the people here when they first got into their first v8 sports car.
SBC were never known for being very high reving excpet for a select few namely 67-69 Z-28 302. Other then that they were your mid range rpm engines peaking HP around 3500 rpm.
Shifting near the redline is perfectly ok. Like said above, stock engines are boring and looow reving, but you said you have mods on yours, so it will likely rev nicely.
Here's my 383 lt4, redline at 6600rpm, shifting at ~6500 with no losing any power.
What cam do you have? And is your car to tuned to disable all the safety features related to high revs?
NICE videos man!
I have a 510 lift 276/290 degrees duration
And no, that is my problem. My engine is built to run high RPM but the computer is standing there with its arms crossed saying NOPE! That 1500 dollar tune is kind of daunting, especially since I want to do some body work and a new paint job soon.
I am still very new to everything corvette. This site has been invaluable.
Your problem has nothing to do with being a Corvette.
