valve cover gaskets
Old Mar 8, 2014 | 09:38 AM
tntwolt's Avatar
tntwolt
Default valve cover gaskets
went to start changing gaskets. drivers side leaks more and looked easier, ha! lug on alternator/ air pump bracket stopped it. if i grind some clearance will it come off? something in the back is also stopping it. other side i`ll do when it gets warmer, i see the a/c has to be moved. will have to raise car, this leaning over kills the back of my legs. thirty years ago i would think nothin of doing this, man does the golden age suck!
Old Mar 8, 2014 | 11:26 AM
John A. Marker's Avatar
John A. Marker
You will have to remove the bolts from the alternator and swing it out of the way. Then remove the air pump. This will allow you to get the driver's side cover off.
From memory, the passenger's side will come off with a little playing without having to move the air conditioning out of the way.
Old Mar 8, 2014 | 12:22 PM
tntwolt's Avatar
tntwolt
on an `87 right? and the EGR hose on right side will move?
Old Mar 8, 2014 | 12:28 PM
John A. Marker
The EGR "tube" should be on the passenger's side. You may have to remove that...PITA to get back on because of the crimp ring.
My 85 didn't have the tube and the 95 doesn't either. Added in 86 I believe.
Old Mar 8, 2014 | 12:40 PM
Dt86's Avatar
Dt86
The EGR "tube" should be on the passenger's side. You may have to remove that...PITA to get back on because of the crimp ring. My 85 didn't have the tube and the 95 doesn't either. Added in 86 I believe.
I'm dreading doing my 86. What great engineering.
On the driver side you can also remove the wiper motor cover to gain clearance. You would just have to remove 3 screws and disconnect the wiring.
Old Mar 8, 2014 | 02:23 PM
Dt86's Avatar
Dt86
Originally Posted by Dt86
I'm dreading doing my 86. What great engineering. On the driver side you can also remove the wiper motor cover to gain clearance. You would just have to remove 3 screws and disconnect the wiring.
As you can see the driver side can be removed without touching anything up front.
Old Mar 8, 2014 | 07:43 PM
tntwolt's Avatar
tntwolt
Attachment 47773737
ok, but it looks like a plug wire clip is keeping it from lifting off, do i just shove it back? how about passenger side, removing EGR hose give enough room?
Old Mar 8, 2014 | 08:12 PM
Dt86's Avatar
Dt86
You can just push anything out of the way you need to and it will come off fairly easy. I haven't taken the passenger side off yet but it looks a treat, especially since mine has the crimp ring.
Old Mar 8, 2014 | 08:43 PM
tntwolt's Avatar
tntwolt
and the injector wiring, nice piece of engineering to put it in the way, why didn`t they run them under the plenum?
Old Mar 8, 2014 | 09:08 PM
Dt86's Avatar
Dt86
Oh I could go on for days..... Lol
Old Mar 9, 2014 | 12:49 AM
Cliff Harris's Avatar
Cliff Harris
The accessories moved around, depending on the year. Here's info that works on my '86.
The trick on the driver's side is to cut off the end of the bolt that goes through the bottom of the A.I.R. pump (or you can just back it off enough that it no longer sticks out):
There is a bracket on the rear of the head that holds the spark plug wires. The valve cover will hit it when you try to move it toward the rear. I bent that bracket rearward, but you will still have a problem moving the valve cover to the rear because there is a metal baffle under the PCV valve. That baffle will hit the rocker arms and limit how far you can move the valve cover.
On the passenger side, the trick is to unbolt the EGR tube at the intake manifold and then bend it out of the way. The part under the heat shield is corrugated and is quite flexible. You don't need to remove the Oetiker clamp at the bottom.
Old Mar 9, 2014 | 07:40 AM
Joe C's Avatar
Joe C
because if they did, someone would be bitchin' about that! seriously, it's all about manufacturing and production - comes under the heading of integrated product development, and the manufacturing process and the sequence of events. in the big picture, the engine is, somewhat, a sub-assembly to the complete car. when the completed engine is mated to the chassis/body assembly, it would be damn near impossible to route those injector harnesses' under the plenum on an assembly line. as far as a "nice piece of engineering," I love it when people pick apart 30 year old designs!
Old Mar 13, 2014 | 01:37 AM
Dt86's Avatar
Dt86
Back together again
Old Mar 13, 2014 | 02:33 AM
DinoBob's Avatar
DinoBob
Sweet. I see you also have iron heads on your silver 86. We should compare VINs. Any tips you have on this in addition to what you posted?
Old Mar 13, 2014 | 03:06 AM
Dt86's Avatar
Dt86
Yup mines an early 86 also, but white. I always keep a note pad handy and write down each step i do so I don't forget something when I go to put things back together. I usually have 3-4 different things apart at once so that's mandatory for my short term memory lol.
It was a lot of prep work smoothing out the crappy valve cover castings and I'd probably just buy new ones next time. Here's a good tip. Put masking tape on the ends of your valve covers to protect the finish when you re-install them. It's tight and mine got scratched up a little. I was able to spray the paint in the cap and use a brush to touch it up. Lesson learned and hopefully this helps someone out in the future.
I went with the felpro permadry gaskets and I haven't fired it up yet, so we'll see if I get any leaks.
Old Mar 13, 2014 | 04:09 AM
Cliff Harris
Mine leaked at one of the studs. The oil came up the stud and then ran down the spark plug wires and dripped onto the exhaust manifold. I put new PermaDry gaskets (the old ones were also PermaDry) on and it still leaked. I finally solved the problem by putting RTV around the stud on the head and the valve cover.
Somehow the oil was sneaking around the gasket and getting to the stud. It was only the one stud that leaked -- front one on the driver's side. All the others were OK.
Old Mar 13, 2014 | 11:39 AM
Dt86's Avatar
Dt86
Originally Posted by Cliff Harris
Mine leaked at one of the studs. The oil came up the stud and then ran down the spark plug wires and dripped onto the exhaust manifold. I put new PermaDry gaskets (the old ones were also PermaDry) on and it still leaked. I finally solved the problem by putting RTV around the stud on the head and the valve cover. Somehow the oil was sneaking around the gasket and getting to the stud. It was only the one stud that leaked -- front one on the driver's side. All the others were OK.
Fired it up this morning and brought it up to temp. No leaks as of yet. If mine leaked I would want it to leak at the stud like yours did. At least that was an easy fix.
To valve cover gaskets
