This is an indicator that either the alternator or the battery is going to need replacement.
Or the car has been sitting over winter and the battery has discharge...will go away after driving 10+ miles...if it doesn't then either battery or alt going bad.
Also could be a charging issue, but check the above first.
I found on 96 and 93 the connection just aft of the battery, (Positive RED connector) on removal of bolt at the connection and you just may find light power ,clean off and your problem is over... The battery vents gasses, bingo problems
