Correct Wheel Offset
Any suggestions are much appreciated including recommendations as to some specific wheels that will work on my car.
Thanks ........... WS
http://www.worldoneperformance.com/b...-offsets-work/
http://www.tirerack.com/wheels/tech/...jsp?techid=101
I have stock 9.5" rear sawblades and sent them in and had 1" added to the width inward, and am running 13" rear tires. I have 1/16" of clearance to the dog bones, Good place http://www.weldcraftwheels.com/
Don't go with 36mm Offset will stick way out.
I will snap a picture how these look. Pricey
The wheel center is bolted to the hub
The rim itself can be positioned ( offset ) anywhere in relation to the center
so in say the case of a 10" rim ;
it could be 5" + 5" ( zero offset )
or 6" + 4"
or 7" + 3" .
The center doesn't change
The chart referenced in #4 can be confusing particularly for someone that doesn't understand completely wheel construction. Simply put if you're dealing with wheels of the same width an offset with a "lower" number will move the tire/wheel combination towards the outer hood edge or quarter lip, a "higher" number would move the tire/wheel inboard creating less clearance to the suspension components.
56mm vs. 45mm would move the tire/wheel 11mm outboard and is generally considered aesthetically quite good and should create no issues. A 60mm wheel would move the tire/wheel inboard 4mm and result in 4mm less clearance to the suspension components, again should still be aesthetically OK.
If you want to measure just drop a plumb-bob from the outer lip of the hood to the ground at the wheel hub center and the same at the rear quarter lip and measure from the tire to the plumb-line. A lower number will move the tire/wheel closer, a higher I think you can visualize.
Any number less than those or greater than those you mention could be considered questionable BUT only if you're comparing wheels of the same width.
Do the plumb-bob measuring and learn - it's much easier than it sounds and much easier to visualize the potential results.
Offset has nothing to do with the wheel attachment to the hub BUT there are different style wheel nuts required for some after-market wheels - you need "CORRECT" hardware.
If you're comparing wheels of different width it's a much different effort.
The CF has a "COMPARISON CALCULATOR" that does quite well - spend some time with it and you can get quite proficient. I don't use it but it's there and can be very useful - the others referenced in this thread I don't use either. I'd suggest the CF because if you had questions everyone would be working with the "same tools"!
http://forums.corvetteforum.com/tire_rim_calculator.php
I will snap a picture how these look. PriceyThe Best of Corvette for Corvette Enthusiasts
