Fuel...engine problem
Old Mar 16, 2014 | 04:48 PM
7Cav's Avatar
7Cav
Navigator
Default Fuel...engine problem
Fellow cockpit jockeys ,
My 89' has seen too many shops...tired of it. I want to fix & sell her. Newer bat, newer fuel pump, vac line replaced. the problem is when I crank her it starts but then dies even if I pump more gas. A very strong odor of gas begins to fill the garage.
I appreciate any help you can provide. Oh, she has 141,000 miles on her
Old Mar 16, 2014 | 06:47 PM
ckwhite's Avatar
ckwhite
Default Don't Give Up So Easily
My '89, with 100K has seen the inside of many shops - more than yours I'll bet. But that L98 is so bulletproof that I won't give her up for a long time. Find a decent CV mechanic who can deal with your fuel problems - intelligently - (tell them what you've already done). Your '89 (if you haven't trashed it) is one of the best-looking, best-running Corvettes out there!
Old Mar 16, 2014 | 08:08 PM
z06scentair's Avatar
z06scentair
Sounds like a bad fuel injector (s). Have you or a mechanic completed a psi test? Did the pressure hold for ten minutes?
With the strong smell of fuel, it leads me to believe one or more injectors are leaking. Remember the older fuel injectors were not designed to run on alcohol based fuels which can cause rust/buildup to block or stick an injector.
Old Mar 16, 2014 | 09:17 PM
larryinalabama's Avatar
larryinalabama
If no codes are present, it could be fuel injectors.
What state are you in? Reason I ask is I alaways wanted the 89 but wound up with a 1990.
Old Mar 16, 2014 | 10:24 PM
Silver96ce's Avatar
Silver96ce
First - if you don't already have it, purchase a factory service manual. Use it to diagnose this problem and then repair it using the manual. The manual has simple to use diagnostic trees. You can sell it with the car when you are done repairing it. While you are waiting for it do the following.
Next, carefully inspect underhood for evidence of fuel leakage. Also check under fuel filler rubber membrane and underneath the car following the fuel lines to the filter and the engine.
Third, check the fuel pressure regulator - the symptoms sound like it is ruptured and leaking fuel. If not look for leaks in the fuel rail and around the injectors.
Oh and be extremely careful not to run the engine for any length of time - fuel smell is bad but fire is worse.
Old Mar 16, 2014 | 11:31 PM
7Cav's Avatar
7Cav
Navigator
Default 89' fuel/ starting problem
I'm in east Texas
Old Mar 16, 2014 | 11:36 PM
7Cav's Avatar
7Cav
Navigator
Noo she hasn't been trashed. Much new , orginal engine , etc. Problem being talent is hard to find here in the Piney woods of Texas. By the way it is a conv. By the way injectors were new 6,000 miles ago...6yrs.
Old Mar 16, 2014 | 11:47 PM
Silver96ce's Avatar
Silver96ce
Take a look at this video -
Forgot to add you only need to watch about the first five minutes. There are probably other videos showing the replacement process but I only did a quick search for this one.
Old Mar 17, 2014 | 01:55 AM
Cliff Harris's Avatar
Cliff Harris
To check for a ruptured FPR (Fuel Pressure Regulator) diaphragm, pull off the vacuum line. Turn on the ignition without starting the engine. If fuel comes out of the vacuum fitting on the FPR then the diaphragm is ruptured.
It caused a fire in my car, so don't let this go.
Another possible cause of a fuel smell is the vapor line that goes from the gas tank to the vapor canister. There is a rubber hose that joins two metal lines that can break. It is located in front of the driver's side rear tire:
Old Mar 17, 2014 | 10:22 PM
7Cav's Avatar
7Cav
Navigator
1986 C4 Corvette Fuel Pressure Regulator saga - YouTube
I looked...didn't see evidence of leakage there but did find fuel leakage on drivers side of the engine in between injectors.
??????? ideas
Old Mar 17, 2014 | 11:21 PM
Silver96ce's Avatar
Silver96ce
I don't have a TPI setup but IIRC if you pull the plenum you should have access to the fuel rail and injectors. There are o-rings for the top and bottom of each injector along with o-rings for the tube ends connecting the fuel rails and at the fuel pressure regulator - any one or more of these can be leaking.
Here is a do-it-yourself page for TPI with a diagram of the fuel rail and its components -
http://chevythunder.com/do_it_yourse...d%20Components
Here is a link to FIC web page for L98s - you can get a fuel rail rebuild kit for $30.00, rebuilt injectors for $189.00 and a new fuel pressure regulator diaphragm for $49.95. All for $270.00 and your fuel injector system is completely rebuilt. And if you have a problem, Jon the owner knows his stuff. This is what I would do at this time.
http://fuelinjectorconnection.com/sh...hp?groupid=101
Oh and if you already haven't done it - change the fuel filter.
Old Mar 17, 2014 | 11:44 PM
Smokeysvette's Avatar
Smokeysvette
7Cav where are you located in E.TX? I also live in E.Texas and I might can help you out.
Old Mar 18, 2014 | 02:01 PM
7Cav's Avatar
7Cav
Navigator
I DO appreciate the offer...Cherokee County>> Alto area.
Old Mar 18, 2014 | 02:07 PM
7Cav's Avatar
7Cav
Navigator
I very much appreciate the info. Fuel filter was changed last year. I will post when this " party " is over ...
Old Mar 23, 2014 | 04:55 PM
Smokeysvette
I'm a bit away from you (north of Wills Point) but wouldn't mind meeting up maybe at a Corvette event or maybe just take a cruise some day and meet up to discus the problems your having over some cold ones or coffee. I'm retired so no time and day constraints for me.
Old Mar 23, 2014 | 11:16 PM
7Cav's Avatar
7Cav
Navigator
Sounds great....need to get Miss Blue up & going first. I will let you know...I'm retired also.
John
Old Mar 24, 2014 | 07:44 AM
newbie2vette's Avatar
newbie2vette
John
It could be any early stage before one of your injector goes bad, start unplgging one injector at a time. Unplug one then start it, once you unplug the one going bad it will stay running. I say that because the 89 I revive several months ago did the same thing after I finally got it to run, then it started doing you're experiencing, until I isolated each injector. I made an harness to test individual injector, you can hear them clicking if you do this.
To Fuel...engine problem
