I have an 89 C4 coupe
I was wondering if I can remove donut spare and replace with full size tire.
I know the spare tire holder can be lowered. Is there sufficient room to accept a full
size spare?
If so, has anyone done this and will it be bulging out too far?
Does anyone who has done this have any pictures?
Thanks ... Joe
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
size spare?
Thanks ... Joe
Yes you can do that, but it will stick way down and not look very nice
The tray will hold a 275/285, but nothing larger. As Cruisinfanatic
suggests, not only will it look strange, but the tray bottom will be
subjected to speed bumps, etc.
And now you see why they went with a "space saver" spare to begin with.
Thanks for pic... I get the hint.
I think I'll leave it be as is.
I just don't understand when some forum members state the spare is there for protection on impact.
When I dropped the spare tire holder, everything seemed rather loose and not too stable. Am I missing any parts to keep things in a rigid stable intact stationary position?
Things that make a Vette owner go Hmmmmm.
My 1985 original spare is still under the car. It looks fine with no dry rotting that I can see and the rim is in perfect untouched condition. Would it still be safe to use for a short distance run in case of a flat tire?
There should be no movement (or looseness) at all.
When installed properly and tightened up, it does not move.
Can't say what you might be missing, but from your description something isn't right. Either missing parts or not installed correctly.
Thanks.... I'll have a mechanic check it out for me.
No need for a mechanic, unless you would rather not get involved.
The 'tray' is suspended by two hooks in the rear, and one bolt
accessed in front (at the rear of the vette). The bolt size is the same as the lug nuts, so you can use the lug wrench to unscrew the bolt, and lower the tray.
With the bolt removed, the aft end of the tray will lower to the ground showing the spare, and possibly the jack. Just check the
tray mounting on the hooks, as there are two levels of adjustment
to accommodate a larger tire.
If all connections look OK, replace and tighten the bolt.
I don't understand when some forum members state the spare is there for protection on impact.
The C4 Spare Tire offers ZERO impact safety.
From an engineering point of view, the absence of the Spare Tire will increase, and help the rear crumble upon impact therefore greatly decreasing the odds of injury.
Most C4 Owners remove the Spare Tire completely.
Then why did GM put a brace in place of the spare when they added run flats? The spare tire delete option from the factory has this brace. I firmly believe that if it wasnt needed they would not have put it in.
Does your engineering theory coincide with the idea behind the now proven unsafe Corvair and Volkswagon Beetles of the 60's? In other words, the less those cars had in front of the driver, the more chance of serious injury to the driver. Shouldn't the same principle be applied to the rear of any car? Crumple zones in newer cars let the car absorb impact and do improve safety standards for sure, but there are always objects designed in to help take the impact. Crumple zones are merely folding points for the body. The idea of not having other substantial objects there to help absorb the impact doesn't make sense to me. I tend to think most C4 owners now remove the spares because of their age and the extra weight they may want to reduce.
Removed the spare & related hardware last summer when I painted mine, and decided to leave it off.
Tire/rim was in such bad shape it couldn't be used if needed.
Less weight.
Incredible access to mufflers, rear end and fuel tank.
The only benefit to safety in a rear ender may be the weight of the tire/rim would help absorb a tiny bit of energy. If that becomes a factor, I'm having a real bad day.
I have AAA anyways.
Can anyone send me a pic of how the spare is supposed to be stored?
1989 coupe. My spare was crammed with jack and the rim is badly bent. I'm going to get another spare but want to make sure it gets out back correctly. I have a spring, bag of jack & tools and the spare tray. I assume the tire goes up against the gas tank? The bolt at the rear seems too long, but looks correct.
Can anyone send me a pic of how the spare is supposed to be stored?.....
On my '85, the jack was stored in the passenger side storage bin behind the seat, not in the spare tire area.
Regarding the bolt being too long, you can see the bracket on the left that it is secured in. The "T" on the end of the bolt rides up in the valley at the top of this bracket. When you loosen the bolt to remove the spare, the "T" on the top end of the bolt allows you to move it up over this valley and lower down. To put it back together, you push up on the assembly with the tire in there, put the "T" back up in that valley in the bracket, then tighten it down.
I know I didn't explain that very well....(the pic on the right with the bracket removed was from a different post showing easier access to the tail light bulbs with this bracket removed)
Thanks,
I thought the jack went in the storage bin as it has a sticker with a drawing showing how it's placed in there. That's where I put it. I could not find the jack and tools when I bought the car so I got a set from a parts car and put it in the bin. Now when I took the spare down, I found the bag with a jack and tools, but it didn't look like it belonged there.
There was also an L-shaped spring on top of the spare. It is fairly heavy gauge metal. I guess it's to hold something down or keep something from rattling?
Thanks,
My 85's jack was stored in the bin behind the passenger seat, but not 100% sure that's where it is supposed to be........ Anyone else know for sure?
