C5 wheels on a C4?
Old Mar 20, 2014 | 09:36 AM
Redspider's Avatar
Redspider
Default C5 wheels on a C4?
Sorry to ask this.
I'm sure this has been asked a billion times.
Will stock C5 wheels, fit my C4?
Old Mar 20, 2014 | 10:15 AM
Kmcoldcars's Avatar
Kmcoldcars
Always state the year of your car and other pertinent information about it. The C4 was made for 13 years, with 5 different engines, at least 4 different transmissions, and various body and interior changes. My 1991 and 1992 look the same from the outside, but they have different engines, transmissions, and the dashes and some of the electronics are different. The 1992 has ASR, which the 1991 does not.
To answer your question, I believe C5 wheels are a direct fit for 1989 and up Corvettes. The earlier ones will require spacers. (I may be wrong on the year change - it may be 1987). Someone will correct me if I am wrong.
Old Mar 20, 2014 | 11:01 AM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Correct, all 1989 to 96 corvettes can use C5 wheels. C6 wheels will need adapters.
C5 ZO6 wheels fit the best
Old Mar 20, 2014 | 01:34 PM
94flavette's Avatar
94flavette
I thought it was 84-87 and 88-96 with the suspension change prior to the 1988 MY?
Old Mar 20, 2014 | 02:46 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The change was made in '88 to the suspension that uses the later offset wheels.
Although I don't care for the C5 wagon wheels, I tried them on my 94.
Here is a picture to show what they looked like for sizes and how well they fill out the wheel wells.
I didn't like them. They looked ok, but the 17" front and 18" rear made the car feel too high in back. I also had the stock C5 Goodyear run flats on them and they are very stiff so I didn't like the ride either. The tires were the stock C5 sizes 245/45/17 front and 275/40/18 rear.
I went back to C4 wheels.
Good luck with your choice.
Old Mar 20, 2014 | 03:36 PM
Marksgotavette's Avatar
Marksgotavette
I am also looking to put C5 wheels on my 1989 convertible. I am looking at the chrome ones. But I also want to put the MGP red caliper covers set from Ecklers behind them. Will these new C5 wheels that have a 54mm offset still leave enough clearence for the covers?
File Type: docx
Old Mar 20, 2014 | 10:11 PM
Redspider's Avatar
Redspider
I have an 84,
The photo is of the rims I am looking at. I have no idea what year the C5 car is.
Old Mar 20, 2014 | 10:21 PM
1993C4LT1's Avatar
1993C4LT1
Redspider, not sure what year C5 that is either. If it helps, those C5 rims were used from 2000-2004.
Old Mar 21, 2014 | 08:54 AM
Redspider's Avatar
Redspider
Did bolt patterns stay the same? IF it needs spacers, not sure what to buy.
Old Mar 21, 2014 | 09:33 AM
WVZR-1's Avatar
WVZR-1
If you're looking at used C5 wheels you need to inspect them quite closely - there were issues with "fractures"!
You actually need to be concerned with the offsets and widths of wheels you buy if used. A C5 appearing wheel could be a "replica" and not even a C5 offset. The offsets and sizes are cast on the wheel back-side of most. If you're looking at used "assume nothing" - get the information and come back with the information.
There's no such thing as "they'll all fit"!
Old Mar 21, 2014 | 04:33 PM
Redspider's Avatar
Redspider
Sounds like I better let them past and just buy a new set.
Thanks for every ones help.
Old Mar 21, 2014 | 04:42 PM
WVZR-1's Avatar
WVZR-1
If they're local just check them very closely for possible fractures and get the information. If they've already got tires on them mount them and see what you think of the look. You should be able to mount just one side and make a decision. The manufacturer of the C5 wheels I believe are cast in them also. Some had more issues than others.
Do a search in the C5 section for cracked, broken wheels or wheel fractures. There should be many. Don't pass up what might be a good buy. Spend the time to check them out before spending the money though.
To C5 wheels on a C4?
