Converting a 93 to 134a. So I can eliminate the adapter on the accumulator charging port I'm thinking putting a 96 accumulator and hose. The 96 hose has the proper fitting for 134a so no adapter needed. Anyone know if the connections are the same and if this is doable?
Hi
There are R12 to R134A adaptors that screw onto the R12 port, 1x for low side (blue) and one for the high side (red)
