Spare Tire Help....
Old Jul 17, 2002 | 11:46 AM
Izover4u's Avatar
Izover4u
Default Spare Tire Help....
hye guys well i got a flat... and got it fixed.... i had to use my spare tire... The problem i am having is putting it back... The carrier is sitting lower... I think it is in the position for a full size tire... How do i put it back for the Small spare tire... Thanks guys.. :cheers:
Old Jul 17, 2002 | 12:53 PM
1Patriot's Avatar
1Patriot
Default Re: Spare Tire Help.... (Izover4u)
Raise the hinged cover to the second position, add spare an lift and secure..
Old Jul 17, 2002 | 01:03 PM
scorp508's Avatar
scorp508
If you look where the carrier attaches/hinges there are two positions. Raise it to the higher one and you'll be good to go. :)
Old Jul 18, 2002 | 01:20 AM
Izover4u's Avatar
Izover4u
i put it to that second setting.. the problem is the long bolt... it seems really long now... is there a way to raise that???
thanks :cheers:
Old Jul 18, 2002 | 01:27 AM
scorp508's Avatar
scorp508
Oh the bolt, ok. It probably isn't in the right spot. It can easily slip out. You'll have to look at it to really understand what I mean. It can slip back towards the license plate and down out of it's holder easily. If you take the plate off you'll see waht I mean. :)
Rotate it the right way and slip it back up into place.
Old Jul 18, 2002 | 01:34 AM
Izover4u's Avatar
Izover4u
Default Re: (scorp508)
thanks.. im goin to go check it out today... :D
Old Jul 18, 2002 | 03:08 AM
GDP's Avatar
GDP
Default Re: (Izover4u)
Might wanna clean yours out while you're down there, mine was absolutely FILTHY! 31,402 miles worth of dirt. :U
It's all spotless now though. One step closer to total Corvette enlightenment. :yesnod: I also put a tire treatment on my spare because it was getting brown everywhere.
To Spare Tire Help....
