Opti Replacement? 1994 Corvette
Old Mar 27, 2014 | 11:18 AM
idprints's Avatar
idprints
Default Opti Replacement? 1994 Corvette
Once everything is removed to get at it.
Are any special tools needed to remove Opti-Spark?
Old Mar 27, 2014 | 11:30 AM
Pete919's Avatar
Pete919
http://forums.corvetteforum.com/c4-t...-pictures.html
Old Mar 27, 2014 | 12:41 PM
1993C4LT1's Avatar
1993C4LT1
Best thread for opti removal
Old Mar 27, 2014 | 01:37 PM
csthews's Avatar
csthews
And a quick answer to your question. No special tools are needed.
Old Mar 27, 2014 | 03:57 PM
JD Shredds's Avatar
JD Shredds
Since we're on the topic of optispark replacement, I've heard you can install the vacuum vents from the later models onto earlier models (i.e you can vent the Optispark on a '92 like you would find on a '95). How easy is that to do?
Old Apr 2, 2014 | 08:12 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
It is not to bad to vent it yourself.... Check out this article. http://www.corvettefever.com/howto/16758/
Old Apr 3, 2014 | 08:13 AM
mxw128's Avatar
mxw128
I used the vented MSD cap and rotor package when I replaced the opti on my 94. Comes with the hose, tees, checkvalves etc. The isolator and cap have the nipples for the hose, so there was no need to drill and tap the base on the opti. No problems so far.
Old Apr 3, 2014 | 09:27 AM
eatmydst1234's Avatar
eatmydst1234
I'm running the same cap and rotor, I did also run a bead of RTV around the cap and isolator. Hopefully that will prevent any oil from leaking in, I need to pull intake and reseal it.
Old Apr 4, 2014 | 08:48 AM
mxw128's Avatar
mxw128
Yep did the same thing, also caulked over the original vent holes (per directions) so that it'd only pull in filtered air...
To Opti Replacement? 1994 Corvette
