Passenger window
Old Apr 1, 2014 | 04:26 PM
RWC112's Avatar
RWC112
Default Passenger window
my passenger window goes down but won't come up I replaced the motor and still will only go down can there be a bad ground or switch driver side works just fine
Old Apr 1, 2014 | 09:42 PM
jv9999's Avatar
jv9999
It could be electrical or mechanical. Does the window go up if you help it? With the engine off, do the interior lights dim a bit when you try to put it up? If the answer is yes to both of those, the motor and wiring is probably good. The window may be binding in the track. Try lubing the felt with spray silicone.
Old Apr 2, 2014 | 01:13 AM
xrav22's Avatar
xrav22
Take out the switch and sandpaper the contact it will probably work again.
To Passenger window
