Fuel injectors
Old Apr 4, 2014 | 10:37 AM
canuck buick's Avatar
canuck buick
Default Fuel injectors
How do I know what size fuel injectors are in my car all I know is that they are black and grey and look old.
Old Apr 4, 2014 | 12:57 PM
ejscarfo's Avatar
ejscarfo
Call Jon at FIC and inquire. He is very knowledgable and will help out. FIC is a supporting vendor here.
Old Apr 5, 2014 | 02:00 AM
aj1988's Avatar
aj1988
I am pretty sure, which means probably wrong, 22lbs. I have FIC's in my 91 and they are definitely worth the cost.
Old Apr 5, 2014 | 08:24 AM
Paul Workman's Avatar
Paul Workman
Ask Jon at FIC for new STAINLESS injectors and you'll be happy.
Old Apr 5, 2014 | 09:39 AM
GKK's Avatar
GKK
89 Vettes have the 22lb. Multec fuel injectors which are not compatible with todays blended fuels.
The coil insulation will eventually deteriorate from the fuel causing a short in the injectors leading to reduced engine performance, which is why many members replace with the modified Bosch III's Jon Banner (FIC) sells.
Old Apr 5, 2014 | 10:10 AM
canuck buick
I guess before I do an outlay of cash for these first I should do a resistance test on each one , they all still might be ok. Thanks for the advice of the FIC ones.
Old Apr 5, 2014 | 10:49 AM
Paul Workman
But, do the test after they're HOT, not cold; very important. (but if they're original, pre 93s, AND you have ethanol, like the man said, they won't handle it. Replace one, replace 'em all, if stock.
Old Apr 5, 2014 | 10:58 AM
canuck buick
wow thanks I would have done them cold
Old Apr 5, 2014 | 02:16 PM
Vetteblack-96's Avatar
Vetteblack-96
Related question: Is there anything wrong with using injector cleaner in your fuel? I think I read somewhere that it's bad idea but I don't remember why.......
Old Apr 6, 2014 | 01:28 AM
GKK's Avatar
GKK
Fuel injector cleaner will slowly deteriorate the coil insulation on the Multec fuel injectors.
Old Apr 6, 2014 | 02:01 AM
samsonb's Avatar
samsonb
I put Bosch III 22# in mine and the BLM's were showing a super lean condition all the time. Ended up putting in the 24# injectors, and the BLM's were in the safe range. Ended up dropping the injector constant in the tune down to around 21.5 to lower the overall BLM's a little bit to keep it running closer to the rich side of the range.
Old Apr 6, 2014 | 11:11 AM
GKK's Avatar
GKK
I have a set of the Bosch III's specifically made for my 91 by Jon Banner, which I tested out for him.
I don't know the BLM count but, my 91 Vette passed California's Emissions test Very Cleanly!...
Old Apr 6, 2014 | 02:17 PM
Vetteblack-96
Thanks, GKK.....I knew I read something about it but couldn't remember what. So what do you do when the injectors start to go bad.....just replace them? I hope I'm not hijacking the thread....this is a related question.
Old Apr 6, 2014 | 03:34 PM
GKK's Avatar
GKK
When the Multecs go bad, replace with the Bosch III's and you're good to go!...Also, Multecs can not be cleaned or serviced.
To Fuel injectors
