C4 suspension
Old Apr 7, 2014 | 06:11 PM
cmrwash's Avatar
cmrwash
3rd Gear
Default C4 suspension
I’m a vette newbie, and my 93 leans to the left. I have seen other C4’s with the same lean. Is this a effect of age and mileage or the way these vette’s are set up?
Old Apr 7, 2014 | 06:58 PM
charliet615's Avatar
charliet615
Mine also leans to the left, i'd also like to know why? 93 convertible. Anyone Know?
Old Apr 7, 2014 | 08:04 PM
1993C4LT1's Avatar
1993C4LT1
Old Apr 7, 2014 | 09:00 PM
gerardvg's Avatar
gerardvg
Check the composite leaf spring is not cracked, also check the rear spring and the long bolts on the ends of rear leaf spring. Check the nuts are at equal points on the thread, standard ones should have a split pin to secure them. Aftermarket ones (longer bolts) are used to lower the car, you may be able to correct the lean to one side by tightening the nut on the side that is leaning to or losen the nut on the other side.
The front spring has shims above between the crossmember and leaf spring, the ends of the front springs have rubber on them. If that has worn on one side that may be it but unlikely as they seat firmly in the lower control arm.
I say upgrade to coil overs, fully adjustable to the ride height you want no compromise.
Street.
http://www.parts123.com/parts123/yb....5Z50000050F~~~
Track.
Old Apr 8, 2014 | 02:49 AM
Cliff Harris's Avatar
Cliff Harris
Previous owner was extremely fat?
Related to what gerardvg said, make sure the exhaust pipes have heat shields where they run under the rear spring. Too much heat can destroy the fiberglass spring.
Old Apr 9, 2014 | 10:10 AM
charliet615
ttt
Old Apr 9, 2014 | 10:14 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I've had 10 C4's they all had a lean from 1/8 to 1/2 inch to the drivers side.
Old Apr 9, 2014 | 11:16 AM
MavsAK's Avatar
MavsAK
Lean to lower center of G on the left side maybe?
Or maybe they set it up that way intentionally so you get wet floorboards on the driver side for not putting your targa back on fully?
Old Apr 9, 2014 | 12:00 PM
davewhtt's Avatar
davewhtt
My 93 leans to the RIGHT and so do i. I dont own anything that would lean to the left...just saying
To C4 suspension
