Automatic transmission Question
Old Apr 12, 2014 | 02:20 AM
L8C4's Avatar
L8C4
Default Automatic transmission Question
A sub-standard transmission shop performed an overhaul of auto on my car before I bought it. They didn't install long enough bolts to hold the tail housing on. The tail housing opened up about 1/4" leaking the fluid out. 3 of the 4 bolts were about 3/4" too short! They must have lost them and thought it wasn't that important. The aluminium from the transmission housing stayed on the threads of the bolts and they able to be pulled out with my fingers without turning them. I am in the process of installing heli-coils to the 3 damaged threads of the housing.
QUESTION. Now that I have removed the tail-housing I have noticed quite alot of "play" in the tailshaft, is this normal.
Thanks Guys
Ryan, New Zealand
Old Apr 12, 2014 | 04:00 AM
Deakins's Avatar
Deakins
It's been more than a few years since I was building those transmissions but if I recall correctly the output shaft doesn't have a crazy tight bearing holding it in place like a manual trans does. Someone that's been inside one within the past decade should be able to confirm this or set us straight.
Old Apr 12, 2014 | 04:52 AM
L8C4's Avatar
L8C4
I hope it's not damaged. I'd like to have some good news with this car for a change. I want to bolt it back together, and if it's good, I'll treat it to a new cat-free exhaust seeing as its off.
Old Apr 12, 2014 | 07:35 AM
Mark8801's Avatar
Mark8801
Thanks Guys
Ryan, New Zealand
Yes, there is a bushing in the tailshaft that once the drive shaft yoke is inserted keeps it centered and from flopping (technical term ) around.
Old Apr 12, 2014 | 11:45 AM
383vett's Avatar
383vett
I was concerned about that years ago when I started playing with these trannies. The output shaft does have a lot of play, and as stated above, the bushing in the tailshaft keeps it in place. The tailshaft bolts do come in two lengths depending on the tailshaft. I've seen both lengths also. Obviously, you want the longer one.
Old Apr 12, 2014 | 12:09 PM
WVZR-1's Avatar
WVZR-1
I believe the extension housing bolts are M10X1.5 and 35mm long for the 700R4. Does that dimension match your one good one? With the extension housing already removed the bushing should be a very straight forward replacement by a shop. If you buy a "seamed" bushing make sure the seam is at 12:00 when installed.
Good luck. I'd think you'll be fine.
Old Apr 12, 2014 | 12:19 PM
383vett's Avatar
383vett
Thanks Guys
Ryan, New Zealand
The op appears to be referring to the movement of the output shaft with the extension housing removed.
Old Apr 12, 2014 | 07:04 PM
L8C4's Avatar
L8C4
Yes, sorry for the incorrect terminology.
And thanks for the responses.
Old Apr 12, 2014 | 11:44 PM
L8C4's Avatar
L8C4
M10 X 1.5 is the bolt that is required. I may have exaggerated a bit in my original post. The long bolt is 40mm and the 3 short ones are 30mm in length. There is no way the short ones were a stock bolt. There is more than 10mm of un-damaged available thread inside the transmission housing. I'll measure that next.
To Automatic transmission Question
