Z52 suspension
Old Apr 13, 2014 | 10:10 PM
dzer's Avatar
dzer
Default Z52 suspension
Hi Guy's: After over a 2 year search, I finally purchased a 1987 C4 'vette. My question is: How do I know if I have the Z52 suspension pkg.? I read on a forum that if the steering wheel dead ends after 1- 1 1/4 turns, that it is a Z52. Mine is 1 turn side to side. Also if it is a Z52, I believe that means other options (ie: beefier radiator) ? It seems to have Bilsteins (yellow). If it's Z52, does it need specific Bilsteins? Thanks.....................Dzer
Old Apr 13, 2014 | 10:47 PM
vetteoz's Avatar
vetteoz
Check the RPO label under the console lid for the factory fitted options
http://www.corvetteactioncenter.com/...o/8496rpo.html
Old Apr 14, 2014 | 12:37 AM
dzer's Avatar
dzer
Default already did it
I did and there are a lot of #'s but nothing that specifically states what suspension pkg. is on the car.
Old Apr 14, 2014 | 06:56 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
In 1987, RPO Z52 included:
B4P-radiator booster fan
FG3-Bilstein shocks
KC4-engine oil cooler
-larger front stabalizer bar
V01-heavy-duty radiator
-faster steering
-16x9.5-inch wheels
Old Apr 14, 2014 | 10:18 AM
c4cruiser's Avatar
c4cruiser
Those numbers and letters represent the RPO codes (Regular Production Option) Is "Z52" listed?? If so, then the car has the Z52 Sport Suspension. The codes are listed in numeric then alpha order so Z52 will be pretty close to the end of the list.
Check out the list of the codes as vetteoz provided.
Old Apr 14, 2014 | 10:55 AM
mixalive's Avatar
mixalive
If it doesn't say Z52, you do not have Z52..
To Z52 suspension
