Help identifying a mystery wire
Old Apr 16, 2014 | 06:20 PM
mixalive's Avatar
mixalive
Default Help identifying a mystery wire
I need help identifying a mystery wire. In the once in a blue moon i decided to check the spare tire air pressure, i found this corrigated tube protected black wire dangling down from the license plate area. The only thing i could think of it could have to do with my back up lights that have never worked on the car. I have never bothered to shake them down as is not required for Texas Vehicle Inspection. What do you guys think? 92 model
Old Apr 16, 2014 | 07:06 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
does your spare tire light work?
Old Apr 16, 2014 | 08:13 PM
mixalive's Avatar
mixalive
I guess not. I didn't know there was one. Where is it located?
Old Apr 16, 2014 | 08:32 PM
mxw128's Avatar
mxw128
If your reverse light don't work and you've got this broken wire there, id say its a great place to start....
You can't see the other end of it someplace where this can reach?
Old Apr 16, 2014 | 09:10 PM
bogus's Avatar
bogus
that's the light for the spare... the backup lights are much higher up.
Old Apr 16, 2014 | 10:15 PM
mixalive's Avatar
mixalive
Anyone have an image of the spare tire lamp?
Old Apr 17, 2014 | 12:27 AM
Cliff Harris's Avatar
Cliff Harris
Here ya go:
It comes on when the interior lights are on so I opened the door to take the picture.
There's something wrong with mine. It's usually much brighter than this. My FSM says it's a #194 bulb.
Old Apr 17, 2014 | 07:01 AM
mixalive's Avatar
mixalive
Originally Posted by Cliff Harris
Here ya go:
Wow. I have never seen that before. I will get under there and look for it. I have owned the 92 for 8 years and still learning things about it.. Thanks for the image.
Old Jun 18, 2014 | 12:34 PM
mixalive's Avatar
mixalive
I found the spare tire lamp. It appears all wires are connected to it as well as wires connected to the back up lamps. So the mystery is still not solved.
Old Jun 18, 2014 | 12:46 PM
WVZR-1's Avatar
WVZR-1
For sure there is only one wire and it's black. You should be able to open the conduit maybe 12" further up and see if there's anything else in the conduit.
If indeed it's a single black wire I believe it would be safe to assume it's a "broken" run to a ground splice and explains why you have no rear back up lamps. I'd connect an alligator clip lead to it and run it to a good ground and see what happens. Rear B/U lamps I'd guess. The wire could also be what's broken or missing at the B/U lamps so look at the B/U lamps also.
The actual ground is way forward and the lamps are all done through splices to that ground.
Even tough maybe not required I'd think it nice to have functional B/U lamps.
Old Jun 18, 2014 | 02:35 PM
mixalive's Avatar
mixalive
Sounds worth a try. Thanks.
To Help identifying a mystery wire
