Shifter Console Plate Refresh
Old Apr 17, 2014 | 05:31 PM
corvettewd's Avatar
corvettewd
Default Shifter Console Plate Refresh
My 95 shifter console plate is looking a little tired with some scratches and one large area on the passenger side where the finish is worn away. I know replacements are available for about $149.95 but can I just remove the piece and refinish it to match the rest of the black trim? I would be interested if anyone has done this and what products you recommend.
Thanks in advance for your help.
corvettewd
Old Apr 17, 2014 | 06:16 PM
Karsten's Avatar
Karsten
corvettewd
I remover all the vents, disassembled them, console stereo face place and shifter panels degrease well and sprayed with Plastidip. Then I did the same with the worn door panel plastic trim pieces.
Karsten
Old Apr 17, 2014 | 06:53 PM
Joe C's Avatar
Joe C
I posted this a couple years ago -
before and after...
http://forums.corvetteforum.com/c4-g...nailed-it.html
http://forums.corvetteforum.com/c4-g...post1579356882
Old Apr 17, 2014 | 10:37 PM
corvettewd's Avatar
corvettewd
Thanks Joe,
I followed all the threads and am anxious to get started. Lots of great info there!
Cheers
corvettewd
Old Apr 17, 2014 | 10:56 PM
Dt86's Avatar
Dt86
I redid my radio bezel when I put a double din radio in. Name:  image-2466185100.jpg
Size:  437.0 KB I used SEM products. Cleaner, colorcoat, adhesion promoter and low lustre clear. With the center console youre going to have to source decals for the windows and mirror.
Old Apr 25, 2014 | 03:19 PM
BigT2's Avatar
BigT2
Karsten
Did you spray the plastidip directly over the factory coating?
Old Apr 25, 2014 | 04:55 PM
Karsten's Avatar
Karsten
Took them apart, soaked in soap and water, dried, sprayed and let dry for a day and resprayed a second coat.
Karsten
Old Apr 26, 2014 | 05:05 PM
BigT2's Avatar
BigT2
How easy did the factory coating come off with the soap and water?
Karsten
Old Apr 26, 2014 | 05:12 PM
Karsten's Avatar
Karsten
The 1993 didn't appear to have any Factory coating. My 1994 had already been Plastidip by the previous owner....I just re sprayed it to clean them up.
Karsten
Old Jul 29, 2014 | 10:54 PM
79C3tnd's Avatar
79C3tnd
After using plastidip on other things previously, I don't think I would use it on my console. I feel it would scrape off too easily, and just looks rougher than the factory finish. I too would recommend SEM products, low gloss/satin clearcoat
To Shifter Console Plate Refresh
