Could someone tell me what the rocker switch on the driver side of the console is for? Also there is a small red light just to the right side of center dash, also a small red light just above the plate of the 35th which shows the number of the car, could not find anything in the owners manual, thanks for any help
There are two rockers on the center console, just forward of the lid that control the power windows. Is the switch mentioned in addition to these two stock switches?
There should be no LEDs in either the dash nor the console plate.
Is there a switch under the driver side hush panel?
Not to sound dumb, but what is the hush panel? The rocker panel I'm referring to is on the side of the console next to the driver, may be something the p o added along with the 2red lights I referred to, will try to get pics and add them, the rocker is just in front of the console lock.
