96 C4 need help
Old Apr 20, 2014 | 08:34 PM
Alex Randolph's Avatar
Alex Randolph
4th Gear
Default 96 C4 need help
I recently purchased a high mileage 96 C4. It ran fine for six days and I drove it at least 500 miles. When I started it the car had the symptoms of a misfire and while driving onto an entrance ramp, the motor died and now it refuses to start. I assume it is a problem with a fuel pump, fuel injector, or fuel pump relay but really have no clue. Any input with ideas for the issue or fixes are welcomed.
Old Apr 20, 2014 | 08:36 PM
wfd1739's Avatar
wfd1739
Originally Posted by Alex Randolph
I recently purchased a high mileage 96 C4. It ran fine for a six days and I drove it at least 500 miles. When I started it the car had the symptoms of a misfire and while driving onto an entrance ramp, the motor died and now it refuses to start. I assume it is a problem with a fuel pump, fuel injector, or fuel pump relay but really have no clue. Any input with ideas for the issue or fixes are welcomed.
What codes did it throw?
Old Apr 20, 2014 | 09:44 PM
Alex Randolph
4th Gear
The dealership ran the diagnostic and said it didn't bring up any codes despite the light being on.
Old Apr 20, 2014 | 10:05 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Need more info. How many miles? Do you have any documentation on when was the last time the PO performed preventive maintenance?
Don't do the nOOB thing and start assuming things. The fact is that you don't know. These LT engine have a weird "mood", and magically it goes away.
To start ensure all ignition wires are completely plugged all the way in.
Old Apr 20, 2014 | 10:48 PM
Alex Randolph
4th Gear
Wires are fine. I was looking for info to go on. It isn't a noob thing to look at potential problems and ask for help. I am new Corvette owner, I'm not stupid.
Old Apr 21, 2014 | 12:27 AM
96GS#007's Avatar
96GS#007
Sounds like the time I had the rotor fail in the Optispark. No codes, just died.
Pretty easy to check all the fueling items.
- Fuel pump should run for 2 seconds when you turn the key to "run"
- A fuel pump gauge verifies pressure at the fuel rail and if it holds
- A noid light verifies the injectors are firing
- Pull a wire and verify spark during cranking.
It's a car. Basic troubleshooting applies.
Old Apr 21, 2014 | 01:09 AM
DrDyno's Avatar
DrDyno
Bad gas (did you recently gas it up?) or... bad Opti.
Old Apr 21, 2014 | 06:48 AM
bac22's Avatar
bac22
What light is on? Also lights only get thrown if the computers see an issue, so I'm finding a bit odd that you're not seeing codes, but not improbable.
But I'm thinking bad optispark, although on the 96 because they are vented then are a bit more durable that older optisparks.
Old Apr 21, 2014 | 10:19 AM
lt4obsesses's Avatar
lt4obsesses
How did the engine "die"?
Did it stumble and miss and gradually quit? Or did it just instantly quit all at once?
Typically a stumble then stall leads me to fuel, and an instant shut off leads me to ignition/electrical.
While this may not always be true, it is a general guide.
Old Apr 21, 2014 | 06:32 PM
gtphillips72's Avatar
gtphillips72
Same thing happened to me. I guessed at a fuel pump problem, replaced it, haven't had a recurrence in two years of driving.
Old Apr 27, 2014 | 08:54 PM
Alex Randolph
4th Gear
It was the ignition coil module. Thank you guys for the help. It is much appreciated.
To 96 C4 need help
