87 convert abs modulator (pump)
Old Apr 22, 2014 | 10:44 AM
Hydro's Avatar
Hydro
Default 87 convert abs modulator (pump)
Can this pump be removed from the inside of the car without going underneath and removing the square black cover ? I can loosen 4 out of 5 lines. The bottom (drivers side) line seems unreachable. Thanks.
Old Apr 22, 2014 | 03:07 PM
jv9999's Avatar
jv9999
Yes, there is no access from the bottom.
Old Apr 22, 2014 | 04:55 PM
hcbph's Avatar
hcbph
Default Pump
IIRC, that's how the FSM says to change it out (from inside). If you don't have a FSM, get one because you'll be needing it.
To 87 convert abs modulator (pump)
