AC control unit.
Old Apr 24, 2014 | 03:59 PM
Estevenson's Avatar
Estevenson
Cruising
Default AC control unit.
Hey guys anyone know what jcould cause the AC to come on after starting the car blow thru the vents for a Minit or two then switch to the defrost vent on the dash. This started after I replaced my heater core. It's a digital AC controller with the outside temp on it. it's a94 Lt-1
Old Apr 25, 2014 | 11:51 PM
sledge_78's Avatar
sledge_78
Estevenson,
There are many, many threads on the Forum which address this exact problem. It is common to late C4's with the automatic digital A/C control unit. Although the fix to the problem is simple, removing the A/C control unit from under the dash (over the accelerator pedal) is a task for one with a flexible body. Once removed, the culprit is the small plastic nipples that is on the control unit which the vacuum harness connector plugs into. These nipples on the later C4's were made of very soft flexible plastic, The nipples collapse when vacuum is applied, restricting the airflow to the valves that open and close the damper doors directing your A/C air flow. This is very well documented here on the forum with detailed instructions and photo's. Just do a search and you will be surprised at the results.
My 96 has the same problem, I need to find a flexible body to help remove the control unit.
Sledge_78
Old Apr 26, 2014 | 03:26 PM
Estevenson's Avatar
Estevenson
Cruising
Originally Posted by sledge_78
Estevenson,
Sledge_78
Ok thank you! what do I put for a search when I check the forum,
AC control Unit?
To AC control unit.
