What did you do to your C4 today?
Old 05-24-2018, 09:20 AM
  #3741
Bckmstr
Bckmstr's Avatar
Awaiting patiently for phone call as had to take my ‘85 to the shop to get looked at for an issue after driving for about 40-50 miles car dies, starts right back up but have to give it a little gas , replaced fuel filter as it acted liked starving for fuel...did a lot of reading as tips all over the board for possible causes, as this is my first c4 ever and still doing a lot of reading and researching and nice having previous mechanic who’s been working on this one for the last 11 years and that all he’s been doing for the past 40+years corvette specialist is on his business card...very nice shop.
Old 05-24-2018, 12:37 PM
  #3742
kael
Support Corvetteforum!
kael's Avatar
Finalist 2020 C4 of the Year - Unmodified
New EGR solenoid showed up yesterday. After various connections in place, the redo of FSM test failed. Dreaded my wiring was messed up. Decided to bench test first.
This morning, did the bench test, using the old as a sacrifice if my setup did the wrong thing. Luckily, the test worked as expected, except for one little problem; the old solenoid was fine and holding vacuum, tiny leakdown. Hmm. While in place via the FSM test, it dropped vacuum over about 7 seconds. Uh, is that "slowly"?
Bench tested the new one, it was junk, not holding vacuum even though I confirmed it was pulling a lot of current.
TIL: If an FSM test says "slowly", don't assume you know what that means. When in doubt, bench test yourself.
Reminder: Test the vendor junk before bothering to install. Doh!
Old 05-24-2018, 08:01 PM
  #3743
84Whitebird
84Whitebird's Avatar
as it came out of the car
cleaned and 1 coat of stripper
after 3 coats of stripper
all the paint off and cleaned ready to paint
a big improvement in my mind
when I'm done both will match the air box
Old 05-24-2018, 08:25 PM
  #3744
gdl2165
gdl2165's Avatar
Very nice work, that's going to look really good when you're done.
Old 05-24-2018, 09:08 PM
  #3745
C5 4me
C5 4me's Avatar
Originally Posted by CVG323
I added yellow LED fog lights. Looks pretty cool lol
I wanna see
Old 05-24-2018, 09:36 PM
  #3746
Mishawaka
Mishawaka's Avatar
Some of the LED interior lighting and a bit of the weatherstripping.
Old 05-24-2018, 10:04 PM
  #3747
CVG323
CVG323's Avatar
Originally Posted by C5 4me
I wanna see
ill take some later tonight. too bright out now.
reminds me of the 90's with all the yellow fogs
Old 05-25-2018, 03:34 AM
  #3748
CVG323
CVG323's Avatar
Quick pics. Phone doesn’t do them justice. Super yellow in person
C5 4me (05-25-2018)
Old 05-25-2018, 05:22 AM
  #3749
FelixP
FelixP's Avatar
Originally Posted by RArline
Recovered one of my seats that I am putting in the car. I bought a set of sport seats as that is what came in the car originally. One of the PO put in c5 seats and they are pretty bad shape also.
Happy with the way it turned out. Will get the other one done next week hopefully. Waiting on some parts for the lumbar hoses connectors for it. They are all brittle and just crumble so going to have to replace them.
My granddaughter got to be the first to sit in it.
That looks great! Which covers did you use? I'm tempted to redo my seats too
Old 05-25-2018, 12:11 PM
  #3750
Whaleman
Whaleman's Avatar
https://www.ebay.com/itm/1PC-High-Pe...53.m2749.l2649
I asked about this in a regular post and was told it was not needed. I wanted to do it anyway. I have a 96 base. I knew the ICM thermal grease would be dried up. I found this tube of Thermal Grease on Ebay for 77 cents with free shipping from China. It is enough to do the job (barely). Cleaned it up and regreased and put back in. Found the water seal rubber on the connector all screwed up so I replaced the rubber part. Dan EDIT: the link is not what I bought. says what I bought is out of stock. Many other options for less than a dollar shipped if you check.
Old 05-25-2018, 05:42 PM
  #3751
hockeyhead019
hockeyhead019's Avatar
Finally got around to replacing my driver side window motor. Pulled the regulator out of the car and dremel'ed through the old mounting rivets and replaced only the motor as opposed to the whole regulator for $250. Silly how happy I am with a functional driver side window. But adds a whole other dimension to driving without the top lol
Cheers to this post for the help: Window Replacement
Only took me about 3 hours to get the whole job done.
Fun fact, if anybody is looking for a motor, I would recommend the one from Rock Auto because they come with low profile screw backers so you don't have to mess around with re-installing rivets or cutting down nuts with a dremel.
car addict (05-25-2018)
Old 05-25-2018, 06:39 PM
  #3752
Wsmcdade1
Wsmcdade1's Avatar
Originally Posted by skyhawk50
Never saw tire stickers. I remember the “crayons” we used to use to white letter tires and add red stripes back in the 70’s.
Yes I also used the white letter crayon back in the day as well as tire black. These are glue on rubber. We'll see how they hold up!
Old 05-26-2018, 12:42 AM
  #3753
xrav22
xrav22's Avatar
Old 05-26-2018, 02:28 AM
  #3754
RArline
RArline's Avatar
They are from Corvette America. I cheaped out and got the vinyl ones leather like. They are fine for me and I think will last for while. I replaced the lumbar bladders and also got new foam. There wasn't anything left of the old bladders but hundreds of pieces of black plastic that I had to look hard to tell what they were as I needed the wires out of the old ones. They aren't included in the new install kit.
I bought them from Willcox and used the coupon was a little shy of 400. Seat covers,install kit, and pull tool.
Had bought the seat foam and lumbar bladders a little while ago. Probably around 300 for them also. Plus the cost for the seats. So I went for vinyl to keep cost down a little.
Old 05-26-2018, 09:57 AM
  #3755
84 4+3
84 4+3's Avatar
Received 1,373 Likes on 1,061 Posts
Drove it. This was really satisfying...
fparkin (05-28-2018)
Old 05-26-2018, 11:07 AM
  #3756
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Grats 84 4+3
Old 05-27-2018, 10:35 AM
  #3757
kimmer
kimmer's Avatar
Originally Posted by JrRifleCoach
I checked the oil and filled the gas tank..with gas!
Good job!!
To What did you do to your C4 today?
Old 05-27-2018, 12:25 PM
  #3758
84 4+3
84 4+3's Avatar
Originally Posted by FASTAZU
Grats 84 4+3
Thanks. This means it gets driven about 1k miles a year since we got it lol. Wanna start driving her more.
Old 05-27-2018, 12:34 PM
  #3759
brianfiske
brianfiske's Avatar
Default doughnuts
removed car cover, went 2.5 miles to the doughnut shop, on way home some douche in a Mini cooper tried to race me (why??) then went home and put the cover back on before the thunderstorm....
Old 05-27-2018, 11:30 PM
  #3760
kael
kael's Avatar
Driving on a back road, popped over a hill and a deer runs out in front of me. Fortunately, I had some room and proof-tested my C5 brakes; they work.
Quick Reply: What did you do to your C4 today?
