1992 c4
I don't have the owner's manual so I am not sure but does it have twilight sentinel like my c6 did? the lights come on at night but the problem is they also come on during the day even if it's sunny out, and there is no pattern to it, on or off.
the other question is does the oil temp gauge use the same sensor as the oil temp digital read out? because it goes up to 80C but my gauge doesn't.
last thing how do you reset the oil change light
thanks a lot guys.
http://www.gmpartshouse.com/download...93corvette.pdf
Actually "how to RESET the oil change light" might be top of page in the "stickies"! Maybe even the FIRST one!
Is it a Canadian build car or has it been registered in Canada - if yes I'm sure it's had the DRL function either added or if a Canadian Original build it's been there since "day one"!
If your gauge pack is Metric then it's a Canadian build. Look for Z49, T61, U19
Thanks, yes it's a Canadian car for sure, I am not talking about the DRL but all the lights coming on when it's dark enough, like I said my C6 did that but I didn't know if the 92 did.
