85 headlamp motor
Old May 19, 2014 | 12:47 PM
85vegasvette's Avatar
85vegasvette
Default 85 headlamp motor
I know I'm gonna be a da da da, passenger headlight motor works great sounds normal..but every once in a while it hangs up , I tap the side of the motor and it's fine for a while motor replacement?? Doesn't sound like the gear make no noise
Old May 19, 2014 | 01:01 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
When this happens disconnect the motor and check for 12v between the grey and green if its closing, or between the green and white if its opening. If you get 12v either the motor is running but has a problem with the gear, or you have a bind which opens the contacts in the motor.
Old May 19, 2014 | 03:43 PM
tunedport85inject's Avatar
tunedport85inject
i know your problem,if you open the motor assy you'll find worn out brushes
here some pics
i have to bind the brushes against the armature to make it contact better
here what a guy in the forum made
Old May 19, 2014 | 04:54 PM
85vegasvette
pics didn't open , now I am very curious
Old May 19, 2014 | 07:08 PM
tunedport85inject
ok i reload pics
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old May 21, 2014 | 06:13 AM
HlhnEast's Avatar
HlhnEast
Could be as simple as a loose headlamp cover screw binding on the hood. Make sure they are tight and check around the edges of the opening for abrasions.
To 85 headlamp motor
