Re-paint wheels question
Old May 23, 2014 | 10:53 AM
gbarrett's Avatar
gbarrett
Default Re-paint wheels question
I picked up a set of stock ZR1 wheels that have the original paint on them. They have some scratches so before I get the tires mounted and the like, I thought I'd repaint them. Is there something different I need to do to paint wheels, i.e. special paint, prep, etc.?
Old May 23, 2014 | 11:24 AM
Joe C's Avatar
Joe C
for pretty much for a driver, first thing, a good soap and water wash followed by a good grease and wax remover - something like prep-sol. I'd go over them two or three times with the solvent. if the base paint is in fairly good condition, a light sanding is most likely all you need. stock, factory wheels have a polished lip, so, you'll need to do a little masking. if the finish is pretty bad, you may need to sand and prime. for the paint, unless you're a real purest, I'd just get a rattle can of silver wheel paint - something like duplicolor or rustoleum wheel paint. the silver color is close, but not spot on. I doubt that 99 out of 100 people would know the difference anyway. the key to painting is the prep. the more prep time you spend, the better the end result. worse case, if you screw up, you can always strip the paint and start over. there are plenty of youtube videos on wheel refinishing.
