Egr
Old May 27, 2014 | 02:53 PM
Williamlindsey's Avatar
Williamlindsey
Default Egr
well im in the process of replacing my egr valve and waiting on the part to be delivered in a bit. after tearing apart the upper intake, I figured out that the ebr sensor wasn't plugged in all the way got the parts man to check it. it checked out fine, but replacing the egr valve seeing that i have already pulled everything apart and needing to put new gaskets on it figured it might save me trouble down the road. there are some TIGHT places especially with the egr valve .
Old May 27, 2014 | 05:48 PM
Williamlindsey
Default fixed
Well got everything back together, back is killing me. after i warmed up the engine i sprayed starter fluid around all the gaskets on the upper intake with no change in idle. then took it on a 30 mile run just to see if the service engine light came back on, it didn't. yea me. anything else i should do to make sure i got everything back right?
