C4 braking problem
Old Jun 5, 2014 | 01:38 PM
navyvetteran's Avatar
navyvetteran
Default C4 braking problem
I'm a member of the C6 forum and have friend who asked me to see if I can find out about his braking problem with his C4. The following is his problem.
Jim, was wondering if you could ask if anyone ever had an issue with their Vette where the brakes failed but, when it was checked by a mechanic, he said there was no problem. We were driving in the mountains around West Point and, when we were off the mountain, on a straightaway (thank God!), we had no brakes. They came back for the ride home but it was scary. Had it checked out by our trusted mechanic who said everything looked fine and couldn't figure out what may have happened. Wondering if they heated up while we were coming down the mountain??? This happened late last fall .
Old Jun 5, 2014 | 02:04 PM
Dt86's Avatar
Dt86
Thats scary. That is no place you want to lose your brakes! You are going to have to give the symptoms to help people diagnose. I hate my C4 brakes. Never failed but not that great. I was really disappointed in them when I bought the car.
Old Jun 5, 2014 | 06:39 PM
gerardvg's Avatar
gerardvg
What year?
there are the 84-87 with single piston front callipers.
The 88-96 have the dual piston front callipers and have the J55 option with 13 inch discs.
A well maintained C4 corvette with brake fluid changed regularly will have no problems, brake fluid absorbs moistuire and that will lower the biling point of the brake fluid it also causes corrosion.
Changing the brake fluid at least every two years is a must for reliable brakes.
Even the early single piston callipers can do many laps on a track (with high friction hawk pads) we tend to fatigue before the brakes do.
replace the brake fluid with a dot 4 type, do not use silicon fluid with ABS brakes and you should be fine, check the disc's are not worn also.
Old Jun 5, 2014 | 06:55 PM
MissileDoc's Avatar
MissileDoc
I agree with gerardvg, it could be the brake fluid was boiling due to a lowered boiling point caused by water absorption.
Old Jun 6, 2014 | 01:32 AM
Cliff Harris's Avatar
Cliff Harris
If the brake fluid has absorbed a lot of moisture the water can boil (LONG before the brake fluid). When it cools off everything will appear normal.
It's also possible for the brake fluid itself to boil. Same thing -- it's OK when it cools off.
Old Jun 6, 2014 | 12:54 PM
GKK's Avatar
GKK
Mountain driving + Old Brake Fluid = No Brakes!...
Old Jun 6, 2014 | 02:49 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Flush fluid and put some DOT 4 in. Than check your pads as he may have got them hot enough where they are glazed and need to be sanded down or replaced.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Jun 6, 2014 | 02:51 PM
mmccarson's Avatar
mmccarson
Brake pads overheated will fade and will not stop the car. Comes from riding the brakes on the way down.Once they cool off they are OK. Happened to me after coming down a mountain Once. Best to down shift and modulate the brake pedal.
To C4 braking problem
