starter question
Old Jun 8, 2014 | 08:06 AM
nicpete's Avatar
nicpete
Default starter question
Hi all
went out for a ride this morning when i came home i parked the car in the driveway then about 5 minutes later decided to pull it in the garage
and it did not start, battery is good all the interior lights went on like normal,after the car sat for about 30 minutes it started.is my starter going bad ??? any help would be appreciated .93 ruby
as always thanks for the help
Old Jun 8, 2014 | 08:29 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I can tell you while back I had the same problem that drove me crazy, and then I meant Gordon Killebrew of corvettes.
It's your starter is seizing up, but when it cools down everything becomes normal.
Sorry to say replace the Starter is the only fix, and if I was you I put heat shield on our starter, and never had another problem so far, and that was back 1995.
Old Jun 8, 2014 | 03:50 PM
nicpete's Avatar
nicpete
cool thanks for the advice,guess i'm buying a starter this week
Old Jun 8, 2014 | 03:53 PM
MavsAK's Avatar
MavsAK
Starter's an easy job on this car. Good luck!
Might as well replace the positive lead cable if you haven't yet too. You'd be amazed at how much road grime and oils make it's way up the insulation of the starter wire.
Old Jun 8, 2014 | 07:14 PM
WVZR-1's Avatar
WVZR-1
If the starter is the original I believe I'd consider having it serviced locally and I wouldn't be so soon to jump on the just replace and be done with it. You actually need to evaluate the balance of the electrical. It may be heat soak and maybe not. Maybe there actually is a problem other than the starter. You could have the electrical checked with a "carbon-pile" load test and confirm your issues.
What does your voltmeter tell you?
The repair of yours could be half or less of the replacement. You need a local shop that understands electrical. The parts I'd guess for yours are on the shelf and really inexpensive.
Old Jun 9, 2014 | 01:56 AM
Cliff Harris's Avatar
Cliff Harris
You might have had a VATS incident. The starter enable relay should click when you turn the key to the start position. It's located on the firewall at the bottom of the steering column.
Try cleaning your key resistor pellet or use a spare key.
Old Jun 9, 2014 | 08:09 AM
WW7's Avatar
WW7
with Cliff... I wouldn't go out and buy a starter until I found out if that's really the problem...This "does" sound like it could be a vats problem, and you should check it out before coming to the conclusion that it's the starter.......WW
Old Jun 9, 2014 | 09:21 AM
Paul Workman's Avatar
Paul Workman
with methodical troubleshooting anytime as opposed to "shotgunning" (i.e., throwing parts at it until the problem goes away). Too many times additional problems can be introduced by either defective parts being installed, or issues stemming from the improper installation resulting in multiple issues which complicates resolving the initial issue considerably!
I agree with doing a load test. Assuming(?) the battery is good, a "carbon pile" load tester could be used. But, in the years as a mechanic in my college days, and since, all that I have found necessary was to listen for the starter solenoid to "clack" when someone turns the ignition key to START. This will verify the solenoid is being energized in the first place. At the same time, have the headlights turned on bright when testing the solenoid and see if they dim slightly when the solenoid is activated. If there is an audible "CLACK" sound from the starter, and the headlight dim ever so slightly, then there is an excellent chance the starter is at fault...with exception**.
**Because you said it would start after cooling down, chances are the battery cable connections are sufficient. However, checking the connections and cleaning them - while you're at it - is worth doing if only a preventative measure against a problem in the future. All that said, if the voltage (measured across the battery terminals with a volt meter) drops more than a couple or 3 volts with the starter engaged, then the battery should be load tested (free at most any auto parts store) to be sure the voltage drop is not due to an imminent battery failure and not just a high current draw by the starter.
Old Jun 9, 2014 | 12:39 PM
davewhtt's Avatar
davewhtt
Hi all
Try cleaning your key with an alcohol wipe. I always look for the easy way out first! Not that i havent thrown a part or two at the problem over the years.
Old Jun 9, 2014 | 05:41 PM
thecatmac's Avatar
thecatmac
I put a mini starter in this year, smaller, so far, so good. Might want to read up on it...
Old Jun 9, 2014 | 10:11 PM
xrav22's Avatar
xrav22
Your starter is going bad, the electric windings get old and warped inside, as it gets hot they start to rub on the inside of the starter and gets stuck(eggshaped if you will).
When it cools it shrinks a bit . I bought a duralast from autozone for 35 dollars last April(2013) and it still works perfect.
Old Jun 10, 2014 | 06:06 PM
nicpete's Avatar
nicpete
thanks guys for all the advice ,i appreciate it
Old Jun 12, 2014 | 07:38 AM
DaveT91's Avatar
DaveT91
Had similar problems last year.
Good advice from folks here, i did try a differnt key and cleaning the chip on my key to see if it may be the VATS, I ended up pulling off the original starter and had it rebuilt for $100.
It can be removed without taking off much of anything around it (though I did have to take a few claps off a vaccume line to move it a bit) and if youre careful and thoghtful the starter can be manouvered out and back in place.
Old Jun 12, 2014 | 03:41 PM
Vetterin's Avatar
Vetterin
My car was doing the same thing on and off. Have to keep a pipe in the car so I can beat it when it locks up. Just picked up a rebuilt this week and will swap it out this weekend.
To starter question
