o2 sensor locations?
Old Jun 10, 2014 | 10:41 AM
idprints's Avatar
idprints
Default o2 sensor locations?
Where are the o2 sensors located on my 94 c4?
Old Jun 10, 2014 | 11:06 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
On the exhaust pipes, just in front of the Catalytic converter on each side.
Old Jun 10, 2014 | 01:55 PM
STL94LT1's Avatar
STL94LT1
There is also one post cat o2 sensor on the right side.
Old Jun 11, 2014 | 02:48 PM
JoeUser's Avatar
JoeUser
And, they're loads of fun to replace.
Old Jun 11, 2014 | 06:39 PM
John A. Marker's Avatar
John A. Marker
On the passenger's side there is one before the cat where the bend is on the top side of the pipe and one behind the cat on top of the pipe. There is a single sensor on the driver's side before the cat at the bend on the top side of the pipe.
Old Jun 18, 2014 | 02:12 PM
JoeUser's Avatar
JoeUser
Is this true for the '96, as well?
I replaced the upstream one on the passenger side, and am starting on the downstream one behind the cat (having to let some PB Blaster soak in for a day or so, first). I haven't jacked it up on the driver's side yet to determine whether there are two sensors.
Old Jun 18, 2014 | 02:36 PM
WVZR-1's Avatar
WVZR-1
'96 is OBD2 so you will have a total of 4 - 2 in each bank, 1 pre cat and 1 post cat each side. Left side post cat is about 8" beyond the coupling, mid- pipe to convertor.
Old Jun 18, 2014 | 04:05 PM
JoeUser's Avatar
JoeUser
Ah, that explains why I thought I only saw one on the driver's side; the post-cat one was further back than I looked (and likely hidden by the cross brace on my vert).
Thanks!
Old Apr 24, 2025 | 06:53 PM
STARCRASHER22's Avatar
STARCRASHER22
how'd you get the passenger Downstream out? I'm having trouble trying to get angle with any of the tools I'm using did you have to drop the cat?
To o2 sensor locations?
