MSD unit issue
Old Jun 13, 2014 | 10:29 AM
C4 PLAY's Avatar
C4 PLAY
Default MSD unit issue
I have a 94 LT1 which I added a MSD 6al unit. My tach works normal at cruise but when I rev the motor or accelerate quickly the tach bounces back and forth to 0 rpm's MSD tech support send me a tach adapter to correct the problem, but this unit is for an aftermarket tach, not the factory unit I am using. Need some help from any MSD users
Old Jun 13, 2014 | 11:19 AM
383vett's Avatar
383vett
Is the stock tach getting it's signal from the tach output of the MSD unit or is from it's original ignition wiring? I left my tach wiring stock when I installed my MSD6AL digital unit and it works just fine. I do have a shiftlight that gets it's rpm signal from the MSD unit and that works also.
Old Jun 13, 2014 | 03:02 PM
C4 PLAY's Avatar
C4 PLAY
The stock tach is still hooked up in the factory original way
Old Jun 13, 2014 | 03:04 PM
C4 PLAY's Avatar
C4 PLAY
If it makes any difference the car is a 94 LT1 modified 383 with a custom computer tune
To MSD unit issue
