Headlight issues
Thanks!
-Grasp the motor on the good HL motor and rotate it rapidly to get a feel for reaction of the HL assembly.
-Then do the same for the faulty HL.
If the faulty HL does not move the problelm is most likely the bushings.
You can also apply 12 volts direct from the battery to the motor plug and verify the motor runs.
The wiring is:
C1 Pin A - Gry/Blk to LH HL motor assy
C1 Pin B - Grn/Blk to LH HL motor assy
C1 Pin D - Gry to RH HL motor assy
C1 Pin C - Dk Grn to RH HL motor assy
C2 Pin A - Yel to Lt Sw pin J (on trigger)
C2 Pin B - Red to Fusible Link G
C2 Pin C - Wht to Lt Sw pin G (off trigger)
C2 Pin D - Blk to Gnd
C2 Pin E - Red to Fusible Ling F
First I would unplug the headlights from the HLC. To test the RH HL motor jumper the Dk Grn wire to Gnd and touch a +12Vdc jumper to the Gry wire. This should cause the RH HL to open. Do NOT hold the +12Vdc to the Gry wire after the HL is fully open.
Repeat the test on the LH HL motor using Dk Grn/Blk & Gry/Blk wires.
If both HL motors report back for the next test sequence involving the HLC.
Location of fusible links..
Next question, what module is equal to the Corvette module?
