Another New C4 Owner
Old Jun 17, 2014 | 01:06 PM
ViperC4's Avatar
ViperC4
Default Another New C4 Owner
I am new to the site. I am also new to corvettes. I purchased my 94 locally i am the second owner. The car has 54000 miles on it. Borla exhaust, a procharger, and a few other goodies It is an lt1.
I do have a problem with the main fan not kicking on but i had already figured out its the sensor unit above the water pump that is bad. I unplug the unit and the fan kicks on.
I also have a problem with the mixer valve or something on the inside as the unit never will switch air flow. It is stuck on floor and defrost which sucks running the ac as it makes the window condensate
Any ideas suggestions would be appreciated. Thanks ahead of time for the warm welcome...
Attachment 47805003
Attachment 47805002
Old Jun 17, 2014 | 01:28 PM
mmercer's Avatar
mmercer
Nice looking ride...good luck with your projects.
Old Jun 17, 2014 | 03:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Congrats on your new '84...
You may need the FSM for your Vette to trouble shoot that A/C issue as it will have the diagnostic procedure along with details of that system.
Old Jun 17, 2014 | 03:46 PM
mazdaverx7's Avatar
mazdaverx7
Car looks nice!! Is it a 6spd or automatic??
Old Jun 17, 2014 | 03:48 PM
ViperC4's Avatar
ViperC4
thank you sir 1994 though lol.. when i pull the wires off the sensor for the water temp (the one on the frt of the motor just under the intake) the fans kick on no problem. So i assume it is a bad sensor. though i wonder which gage is more accurate on my dash as the needle gauage reads different then the digital.
It is a 6 speed :
Old Jun 17, 2014 | 04:00 PM
CRUZNC4's Avatar
CRUZNC4
2022 C4 of the Year Finalist - Unmodified
Nice Vette and welcome! Keep them Borlas. Best mufflers ever made.
Old Jun 17, 2014 | 04:16 PM
DGXR's Avatar
DGXR
It is generally known that the digital temp gauge is more accurate. The analog gauge does not have a linear scale -- in the upper end of the scale, the analog gauge indicates temps much higher than are present and causes panic to those not aware. Use the digital temp gauge.
Nice car! I love my 1995 LT1 6-speed.
Old Jun 17, 2014 | 05:04 PM
jdog0411's Avatar
jdog0411
For the A/C issue, the 96's have a problem with the vacuum tubes at the control unit under the dash collapsing on themselves and preventing the selection of vents (always blows defrost and on the floor but not the front vents usually). The design was faulty in the 96's but I haven't heard of any issues with that on 94's. May be something to check though.
Old Jun 17, 2014 | 06:12 PM
tbirdsps's Avatar
tbirdsps
Great color choice too.
Old Jun 17, 2014 | 06:20 PM
JD Shredds's Avatar
JD Shredds
Congrats dude. Enjoy it!
Old Jun 17, 2014 | 06:21 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Enjoy your new ride.
Old Jun 17, 2014 | 06:24 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Nice!!
Old Jun 17, 2014 | 08:00 PM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
ViperC4 is it possibly the vacuum check valve that is bad? Or one of the vacuum hose going to or from it? I had that problem with my 89' when I first got it and it is something that happens on many cars.
Old Jun 17, 2014 | 08:21 PM
ChiliPepperGarage's Avatar
ChiliPepperGarage
The white looks great! How does it run with the blower?
Fill out your profile when you can so we know where are you located.
Old Jun 17, 2014 | 08:36 PM
Ozzstar's Avatar
Ozzstar
Enjoy your new car. I just bought a '93 this past weekend. Is your windshield tinted??
Old Jun 17, 2014 | 11:22 PM
1993C4LT1's Avatar
1993C4LT1
Congrats!
Old Jun 18, 2014 | 08:55 AM
ViperC4's Avatar
ViperC4
Thanks for the warm welcome!!! I also appreciate the ideas for the ac/vent problem...i will check it this evening. I am also switching out that temp unit tonight just to play it safer then sorry
The car runs like a beast with the procharger on it. It lays you back in your seat like crazy back end lights right up and slides all over the place! It will break lose in 3 gears.
To Another New C4 Owner
