I got a 87 Vette with 383 stroker fuel injected and will not run,45 days ago stopped running on freeway,lost no electrical but engine quit running have changed fuel pump,ecu,ignition module, knock sensor and fuel pump relay all with no help will not start,any help is appreciated,thanks yes have pressure at fuel manifold have spark,runs ok when spraying fuel in intake manifold,also no codes when using reader
OK you say you have spark and you have fuel pressure so now you need to check injectors for signal if there is no pulse at injectors it won’t run. what is the fuel pressure by the way it could be to low to start car.How long dose it run after spraying it
You need to put a gauge on the fuel rail and test the pressure. You say there is pressure, but it might not be enough to fire the injectors. You should have 39-43 PSI at the rail with the key on and the car not running.
Since you can get the car to run if you spray fuel into the TB that is telling you your not getting fuel. Have you check the injector fuses in the fuse block to see if they are good?
