1996 Power Antenna
Old Jun 22, 2014 | 09:31 PM
PcolaPaul's Avatar
PcolaPaul
Default 1996 Power Antenna
The motor runs but the mast wont extend or retract unless done manually.
Can it be repaired or does the entire thing have to be replaced?
Old Jun 22, 2014 | 10:57 PM
WVZR-1's Avatar
WVZR-1
Generally it can be repaired if the antenna is still the OE/GM assembly.
12525955 is the GM part number for the replacement. It's fairly easily found eBay and other sources.
Old Jun 23, 2014 | 01:47 AM
PcolaPaul's Avatar
PcolaPaul
Thank You!!
just ordered one off E-Bay.
To 1996 Power Antenna
