EGR Valve
Old Jun 24, 2014 | 05:53 PM
browngk85's Avatar
browngk85
3rd Gear
Default EGR Valve
I have an 85 C4 that would pulsate upon acceleration. I disconnected the EGR valve and it stopped. My question is can I leave it this way
and not have any problems, or do I need to replace it.
Thanks GB
Old Jun 24, 2014 | 09:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It's odd that the EGR would effect accel as it's only called for after some time at stead spead with coolant temp >175 deg F.
If you want to leave it disconnected just install a 160 deg T-stat to avoid having the ECM call for EGR while cruzin the highway.
Old Jun 24, 2014 | 10:20 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Try pulling the rubber hose off of the EGR valve. Then insert a drill bit sized the same inner diameter as the metal tube on the EGR valve that the rubber hose came off of. If it"s clogged up, the EGR valve won't work and the drill bit won't go in very far. In that case, drill into the metal tube until it goes all the way into the EGR valve clearing out the clogged passage into the EGR valve. I think about an inch or two if I remember correctly. Reinstall the rubber hose and see if the EGR valve now operates correctly. All this can be done with the EGR valve still attached to the engine by the way. I hope this helps your problem.
Old Jun 24, 2014 | 11:52 PM
Cliff Harris's Avatar
Cliff Harris
You might have a positive pressure EGR valve instead of the negative pressure one that is supposed to be in there. There should be an "N" marked somewhere on the EGR valve (usually after the part number).
Old Jun 25, 2014 | 02:29 PM
browngk85's Avatar
browngk85
3rd Gear
On closer inspection I found the EGR valve clogged. I'll try this drill trick to see if it works before I replace it. Thanks
Old Jun 26, 2014 | 01:48 AM
Cliff Harris
On my car the EGR is enabled when the MAT sensor shows higher than 0.5°F, and coolant temp higher than 133°F, so changing to a 160° thermostat will not affect that. The "cruzin down the highway" thing is part of the TEST for EGR operation.
See this article on positive pressure EGR valves (especially the "EGR PROBLEMS" section on the second page):
http://www.tomco-inc.com/Tech_Tips/ttt26.pdf
Check this article for more info on Corvette EGR valves:
http://tech.corvettecentral.com/2012...egr-diagnosis/
Old Jul 16, 2014 | 12:21 AM
browngk85's Avatar
browngk85
3rd Gear
The drill trick worked Thanks again
Old Jul 16, 2014 | 09:07 AM
FOURSPEEDVETTE
To EGR Valve
