I have a'93 base coupe. The service engine came on and it revealed a code 36. Using the FSM I did the check at the ignition test connector and received a reading of over 4 volts but less than 6. It is impossible for my fat hands to reach the connector on the top of the opti to do the final test. Is it safe to assume, and we know what that means, that I need to replace the opti?
Reason: misspelling
The reason it lasted 120K is your down in FLA. You don't have the hi humid climate like up north here up here it be 40deg and change 60deg. If you not driving your C4 then all that moisture gets inside of the Opti.
