Air Conditioning
Old Jul 7, 2014 | 07:10 PM
Ho84Z51's Avatar
Ho84Z51
Default Air Conditioning
Hello Everyone.
This is probably an beaten to death question but I'm having air conditioning problems in my 84. The compressor clutch is fine, runs great. Gas is fully charged and yet no cool air blows. The car does sit quite a bit and I'm thinking that perhaps a valve is stuck. Any ideas?
Thanks.
Old Jul 7, 2014 | 09:45 PM
jv9999's Avatar
jv9999
How do you know it's fully charged? It could be a bad high/low pressure switch. If you're sure it's fully charged try applying ground and +12 directly to the clutch. It should engage and it should blow cold. If that works, try shorting the switches one at a time.
Old Jul 15, 2014 | 10:44 AM
Ho84Z51's Avatar
Ho84Z51
The local garage has a set of gages they use in air conditioning and they read that the system is fully charged. The compressor kicks in just fine, no problems there. It will just not blow cold and the garage is at a loss of why.
Old Jul 15, 2014 | 10:59 AM
jv9999's Avatar
jv9999
You need a different garage. It's not all that complicated if you understand the basics and have the tools.
Old Jul 15, 2014 | 01:00 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
My 1985's GM service manual/book only mentions using your hands to feel the air conditioning pipes and I believe the accumulator to check and see if it needs more R12.
Old Jul 16, 2014 | 12:35 AM
Hot Rod Roy's Avatar
Hot Rod Roy
You haven't described the problem very well. What has your garage found to be good, and what can't they figure out? Is it a blower problem? Do all of your fan speeds work properly? If it doesn't blow cold, are you saying it blows hot? Does the suction line (at the firewall, where the low pressure switch is located) get cold? Do you have the FSM? Has your garage worked on other Corvette's? It's not that complicated. I agree with jv9999!
Old Jul 30, 2014 | 05:01 PM
Ho84Z51's Avatar
Ho84Z51
Fan works fine at all speeds. Lines are cold to the touch, compressor works fine and comes on when AC is switched on, no delays. No cold air comes out the vents. What is a FSM? "Front Side Mirror'??????
Old Jul 30, 2014 | 06:39 PM
jv9999's Avatar
jv9999
Factory Service Manual. If the evaporator is indeed cold and the blower is running, then air is not being directed through it. The FSM would help you (or your garage) to troubleshoot it.
Old Jul 30, 2014 | 08:22 PM
scotth48's Avatar
scotth48
Temperature door may not be working. May have a bad vacuum line, dry rotted from age. You need the factory gm fsm to work on any corvette! Without it is to be ignorant, unless you have lots of money to spend and throwaway!
Old Jul 30, 2014 | 09:08 PM
Churchkey's Avatar
Churchkey
If manual ac its a control cable or temp door issue.
For ATC: If blower air exits the defroster vents only: The vacuum supply has been lost or there is a control head issue.
If the system changes modes as designed: Either no vacuum to the temp door motor, the temp door motor has failed, temp door is stuck or there is a control head issue.
Good luck.
Old Jul 30, 2014 | 10:53 PM
JVH's Avatar
JVH
Does the temp change when you move the cold lever over to hot?
Old Jul 31, 2014 | 03:09 AM
Cliff Harris's Avatar
Cliff Harris
There is a cable that connects the HOT - COLD lever to the temp door lever. Check that connection and make sure everything is working.
You can also take out the blower motor resistor module from the evaporator housing and see if the blend door is moving from the full cold to the full hot position. It's the rusty part in this picture (full cold position):
To Air Conditioning
