Total Audio System replacement...looking for ideas/tips
Okay gang, this is my first post ever to this forum, so be kind.
I've really loved the tips and tricks posted here on other points, it's really helped out a lot with regular day to day stuff on my 95...so I'm hoping that someone can help with this.
I bought mine about 9 months ago from a guy that took okay care of it, but as any 18 year old car does, it needs some TLC. Almost all of this is interior work. I've decided to start with a replacement of the entire BOSE stereo system. The speakers are driving me nuts! While they still work for the most part, one of them pops a bit...and I just can't live with that.
So I'm looking at tearing out the factory stereo (from what I hear it's actually two pieces, the ***** are the controller and the actual receiver is mounted elsewhere - not sure of the exact location though), removing all of the wiring and cabling, removing the Bose Speakers. Then installing a simple stereo, re-running all power and signal wires, and adding a separate power amplifier for the new passive speakers since they won't have a built in amplifier like the Bose ones did.
I'm not a total rookie - I used to do stereo installations back in the day (late 80s and early 90s), so that's not a concern, really. It's more about getting around the Corvette specific things, like interior panels that have to be removed, etc.
So the questions for this are as follows:
1. Anyone done this before? I'd be interested in any tips, tricks, or shortcuts you could provide as advice.
2. I want to replace the OEM antenna with a shark fin antenna and fill in the hole in the rear quarter. My plan was to mount this to the pillar behind the removable top, in front of the rear glass, centered. Anyone see any problems with this plan?
3. During the interior process, the carpet is probably all going to come out as well. I currently have a black and tan interior, I was considering changing to all black since finding replacement (non-OEM) carpet is much easier if it's just black. Any thoughts on this?
Thanks guys.....much appreciation from a Forum newbie.
-KCP
-KCP
St. Jude Donor '13, '15-'16,'18-'19-'20-'21-'22-'23-'24
I replaced my entire system last year on my 96 ( Bose gold.) Purchased the replacement, single din unit and speakers thru Crutchfield, modern is the only way to go. I only pulled the passenger side seat out and was able to snake the new wires along the console down under the carpet and up to the storage well behind the passenger seat. From there I ran the wires back to the speakers in the rear. I went with the size Crutchfield suggested for replacement speakers as I really didn't want to get into too much fabricating for larger speaks front and rear. I took my time and messed with it on a weekend got it all done. You will also find many guys recommend the double din unit btw . It's fun, get to clean up inside the car and learn a little more about it.
For the speakers, any thoughts? I'm a little concerned with the depths available, especially for the kick panel speakers in front. The rears I'll probably use the existing Bose boxes as a template for speaker mounts, then hide the new speakers under new factory grills so that everything will still LOOK stock in the back for the most part, but be a lot easier to fix if a speaker blows or something like that.
Any thoughts on the antenna part? I'm curious if that would work, although I don't see any reason why it shouldn't.
No help with the antenna sorry. I also cut the carpeting off the rear speaker covers,has to help a little. I used Polk speakers that were proper depth, you may have to ask about other brands or experiment for max room. I am also looking for a set of tan sill / speaker covers for the front so I have an extra set in case I don't like the bare look.
I replaced all my speakers about 18 months ago. Head unit and wiring had already been replaced, so that made life easier.
I used Polk speakers all they way around and couldn't be happier. Used 5 1/4 up front and 6x9 in the back. They dropped in with no modifications and I was able to put all of the factory grills on, so you would have no idea unless you pulled it apart.
While you are at it, I might suggest getting some dynomat or similar material and using liberally in the rear and on the doors at minimum. Really helped minimize unnecessary rattles/vibrations and improved the sound of the speakers, without killing the exhaust note for those times cruising without music. Believe it was about $150 for enough material to do the whole car, with some elft over.
Good luck.
Good luck.
Dynamat is a sound deadening material. It comes in sheets. Think mine were approx 2' x 3'. It is faced with foil on one side and is adhesive on the other. About 2 mm thick.
Refer to this link: http://www.dynamat.com/
As for the doors, I have the insulator installed also. I would suggest putting some on there as well, as it also kills road noise.
The Dynamat is firmly pressed into place using a wallpaper seem roller - a small handle with a wood or hard plastic cylinder on it.
If I were rgeplace the system in my C4 I'd have three added abilities. 1.Navigation/GPS, 2.Backup camera 3.USB stick
Otherwise.. high quality speakers and anything you can do to prevent rattling / speaker movement will always help.
Pro Mechanic
http://www.smokinvette.com/corvettef...ad.php?t=43094
^This was a massive improvement over stock...but still not what I wanted. I'm going to try again, using a quality set of "separates" and hopefully that will work better.
Here is how I did the amps, and sub...
http://forums.corvetteforum.com/audi...-and-pics.html
Pro Mechanic
I completely
