Lowered and found a problem
Old Jul 25, 2002 | 01:43 AM
Glasman66's Avatar
Glasman66
Default Lowered and found a problem
On the left side, someone put in a 1 inch spacer to take up for the bushing that was mangled.
Can you buy a bushing for it or can you get a new set of four for the rear spring?
By the way it looks sweet lowered
Old Jul 25, 2002 | 11:19 AM
Glasman66's Avatar
Glasman66
Default Re: Lowered and found a problem (Glasman66)
Sweet I get to answer my own post :lol:
I founsd them, they are called rear spring cusions. They are sold in a set of four. You can get them OEM or Energy Suspensions.
Handled :smash:
Old Jul 25, 2002 | 11:53 AM
BobMachus's Avatar
BobMachus
I have a poly set I will sell you. Look Here!
Old Jul 25, 2002 | 05:26 PM
SIGALPHC4's Avatar
SIGALPHC4
You lowered the back.....i'd like to see how that looks now
Old Jul 25, 2002 | 07:45 PM
brimee's Avatar
brimee
Default Re: Lowered and found a problem (SIGALPHC4)
Check my sig. Just did it this spring :cool:
front and back
[Modified by 90 Steel Blue, 5:46 PM 7/25/2002]
Old Jul 25, 2002 | 08:34 PM
Preacher's Avatar
Preacher
Cruise-In IV Veteran
Default Re: Lowered and found a problem (90 Steel Blue)
How hard is it to lower? Mind laying a little FAQ on us? I love the slightly lowered look that some cars have... say an inch in the front, 2 in the rear...
Old Jul 25, 2002 | 08:38 PM
Patrick96LT4's Avatar
Patrick96LT4
Cruise-In II Veteran
The driver-side-rear, all things being equal, will sit lower. Was it on that side? Maybe they were trying to even out the ride height without making the rear spring rate different from side to side.
Old Jul 25, 2002 | 11:02 PM
morphious's Avatar
morphious
Default Re: Lowered and found a problem (Patrick96LT4)
Ahhhhh. Answering your own post is like pleasing yourself. :jester
Old Jul 26, 2002 | 09:27 AM
brimee's Avatar
brimee
Default Re: Lowered and found a problem (Preacher)
The front can be difficult. The spring has to come out. Some just take out the shims in the front=about1/4". I also removed the rubber spacer and put the MAD hard plastic spacer in=about 3/4"
The back is easy. Just change the bolts to longer ones. I adjusted mine back down about 1 3/4" with a full tank of gas for the level look.
Old Jul 26, 2002 | 11:34 AM
Glasman66's Avatar
Glasman66
The front was already lowered. But lowering the back is a piece of cake.
Either buy the kit from MAD or buy 2 10 inch 1/2 bolts with 2 nyloc nuts (the ones with the nylon at the crown of the bolt)
I think Chevy used 9/16 bolts but I could not find them anywhere. I thought of drilling out the washers for 5/8 bolts but the 1/2 is strong enough for a 340-380 lb spring.
Jack the car up at the punkin. Needless to say remove the tire on the side you're doing. Then I put a jack stand under the spring near the bolt at the end of the spring. Lower the car to where the bolt is loose. Pull the cotter pin out and yank out the old one. Put in the new one and reverse the procedures.
I might get flamed on the 1/2 inch bolt deal but I'm sure they are plenty strong to hod the spring.
Handling was greatly improved. But power slides are a little hard to come by now :D
Well I guess I'll find out quickly what you guys think of my engineering.
By the way the whole kit ran $5.00 for the rear.
To Lowered and found a problem
