88 Shift indicator
Old Jul 17, 2014 | 01:37 AM
Tommycourt's Avatar
Tommycourt
Default 88 Shift indicator
I have a 88 convertible with auto trans. The shift indicator stays in first gear although I can shift through all my gears. I don't make a habit of shifting from low to OD. I don't have problems taking it out of drive and the tranny shifts fine. Should I anticipate any problems in the future or is this something that should be taken care of. This is my very first Vette so I don't know if I am capable of correcting it myself or having to take it to a shop to have it done. If I take it to a shop, how many hours do you think it would take to get it repaired. Most shops here in Az run between $90-125. I have to admit I am low on cash but I still want to be able to drive it and if I take it to a shop, I need time to save the cash. Has anyone have any ideas? I should would appreciate some help on this. One other problem I have is I am limited on how high I can raise my car due to the ceiling height. Thanks to all!
Tommy
Old Jul 17, 2014 | 01:56 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The red indicator has a prong that fits into a fork on the shift lever; as you move the shifter the indicator follows. Either the prong is not engaging the fork or the prong is broken off.
Remove some console screws to inspect the shift indicator to see what is the issue.
If the indicator prong is broken off you will need to buy a used indicator or console. If the prong is not engaging the fork, adjust it till the two engage as you lower the console lid.
Old Jul 17, 2014 | 03:22 AM
Tommycourt's Avatar
Tommycourt
65Z01,
Thank you for the advise. I will try and do it tomorrow. I appreciate your help!!
Tommy
Old Jul 17, 2014 | 08:07 AM
Triple Black 88's Avatar
Triple Black 88
That's definitly it. You may want to paint it while its out. Mine was faded.
Old Jul 17, 2014 | 08:15 AM
WW7's Avatar
WW7
When I got my 89 it had the same problem, the pointer had jumped out of the holder and I just needed to reinsert it...If yours is broken, below is what you need...You may find it cheaper somewhere else....WW
http://www.ecklerscorvette.com/corve...1984-1989.html
Old Jul 18, 2014 | 11:55 PM
Tommycourt's Avatar
Tommycourt
Thanks WW7 for the info. Eckler's is kind of proud of their stuff but when you have to have something, usually they have it.
Thanks again for your help!!!
Tommy
Old Jul 19, 2014 | 12:53 AM
Cliff Harris's Avatar
Cliff Harris
The slot on the right in the Eckler's picture fits over this pin that sticks out of the side of the shifter:
If you lift the top of the console it's very easy to forget to align the pointer with the pin and then the pointer doesn't work.
Old Jul 19, 2014 | 10:02 AM
C4in mesa's Avatar
C4in mesa
Tommy
Tommy hang on to your money. I will meet up with you and fix this simple problem.
To 88 Shift indicator
