Question about testing fuel pressure
Old Jul 19, 2014 | 08:13 PM
DanielRicany's Avatar
DanielRicany
Default Question about testing fuel pressure
Hi guys. I have a 1985 Corvette with a lot of mods, and I suspect that my fuel pump may be insufficient at this time. My buddy has a dyno that can only go up to 300 rwhp. My fuel pressure gauge doesn't extend long enough where I can tape it to the windshield. If I put the car on the dyno and run it with the gauge hooked up, will it simulate me driving on the road for this test? I want to see if fuel pressure drops at Wide Open Throttle at high RPMs.
Thanks!
Old Jul 19, 2014 | 08:25 PM
smooth1990's Avatar
smooth1990
What Dyno only goes up to 300 RWHP? I have never heard of such a dyno.
Old Jul 19, 2014 | 08:28 PM
smooth1990's Avatar
smooth1990
Thanks!
IF you have access to a dyno and can get the car safely strapped down and make a pull, someone could watch the gauge and you are making said pull and watch for fuel pressure drop.
Old Jul 19, 2014 | 08:31 PM
whalepirot's Avatar
whalepirot
Not much to go on here, but with lots of mods, a longer hose or longer-hosed FPG is a small expenditure with a potentially huge payoff.
The injectors need to be sized for the power produced. and the ECM needs proper programming, which is a project for it to run mods.
DanielRicany
It's not a dyno for tuning or anything. It's in his repair shop and he using it for diagnosing problems with cars.
Old Jul 19, 2014 | 08:32 PM
ch@0s's Avatar
ch@0s
Old Jul 20, 2014 | 09:36 AM
c4cruiser's Avatar
c4cruiser
Then it's not a "dyno" in the sense that it measures power output of an engine. Given the mods you had listed, that "dyno" is not going to support WOT pulls with your car on it. And that is what lots of people are waiting to see from you; the results of some dyno pulls. You need that to determine what power the engine is making so that you can determine what to do next.
There is no reason why a stock fuel pump can't support 400HP. What is critical is that the fuel filter is new, the lines have no kinks or have been damaged and the fuel pump "sock" is clean. OEM fuel pumps have a "pulsator" that can be removed and a short piece of rubber gas line can be installed. The interior diameter of the OEM fuel lines are large enough to support the necessary volume of fuel for 400HP.
Does your car have an adjustable fuel pressure regulator? If not, get one and set it so it provides the stock pressure. Then fuel pressure can be adjusted as necessary.
Old Jul 20, 2014 | 11:23 AM
856SPEED's Avatar
856SPEED
Old Jul 20, 2014 | 12:11 PM
DanielRicany
I'm not trying to see dyno results from it, all I want is to see my fuel pressure when I have a load on the engine under WOT. Which the dyno should provide for me?
I also have an adjustable fuel pressure regulator and am running 60 PSI, but my engine gets progressively leaner the higher the RPMs go. And my tuner was having problems getting that to come down at high RPMs which is what makes me suspect the possibility of an insufficient fuel pump.
Old Jul 20, 2014 | 12:20 PM
ch@0s's Avatar
ch@0s
get a hose dude.. wow!... and you are supposed to be a mechanic?
Old Jul 20, 2014 | 12:30 PM
DanielRicany
I just bought one and its not long enough. I'm tired of wasting money.
Old Jul 20, 2014 | 01:05 PM
ch@0s's Avatar
ch@0s
Stick it out the hood by the wipers and tape it to the WS.
Old Jul 20, 2014 | 01:10 PM
DanielRicany
The hose only goes like 8 inches
Old Jul 20, 2014 | 02:41 PM
John A. Marker's Avatar
John A. Marker
So go to your nearest auto parts store and buy a 3 ft piece of high pressure fuel line, two steel or brass connects to splice the two hoses together and a four screw hose clamps and cut that hose to your gauge in half and splice in the 3 ft hose. Problem solved.
Tape the gauge to the windshield and run it.
Old Jul 20, 2014 | 03:00 PM
MavsAK's Avatar
MavsAK
Seriously high pressure fuel line is cheap.
With all the money you're fixing to spend AGAIN... what's 5 bucks worth of auto parts?
Old Jul 20, 2014 | 03:18 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
NO KIDDING.
Yikes.
Old Jul 20, 2014 | 05:17 PM
856SPEED's Avatar
856SPEED
12 inches is looking for a buddy.......
http://forums.corvetteforum.com/c4-g...-my-buddy.html
Good luck!
Old Jul 20, 2014 | 05:43 PM
ch@0s's Avatar
ch@0s
Old Jul 20, 2014 | 06:55 PM
MavsAK's Avatar
MavsAK
Good luck!
To Question about testing fuel pressure
