1984 Keys
Old Jul 23, 2014 | 07:26 AM
swampoodle-pat's Avatar
swampoodle-pat
Default 1984 Keys
Are there any original 1984 owners who can comment on the number of sets of keys they received when they took delivery of their 1984.
Also, does anyone have any photos of the keys. I am tryingng to determine if the keys had A and B stampings
Old Jul 23, 2014 | 07:31 AM
WVZR-1's Avatar
WVZR-1
Keys for '84 were A & B - the pad on the ignition & door key were separate components. The keys would be stamped A & B also on the blade.
If an ignition lock cylinder had been changed the cylinder is generally done with a "universal key-way" so if your key showed anything other than an A you could likely get it "copied" to an A blank and it should work. That is NOT cut and dried but it is the way most replacement/service cylinders were done.
Old Jul 23, 2014 | 03:17 PM
fredd1's Avatar
fredd1
Two sets were supplied with mine. The ones stamped "A" were for the ignition, the ones stamped "B" were for the door lock.
Old Jul 24, 2014 | 05:54 PM
swampoodle-pat
Default 1984 Keys
Folks, thanks for your input. I will pass on your information.
To 1984 Keys
