85 corvette rev limit
I pulled out of a buddies house yesterday and got into it about half throttle, came out sideways and right around 5,000 ish it started cutting out during the spin. Like a rev limiter. So my question is, what is the actual rev limiter on it? It is all stock except a high output coil and opened air filter lid.
I just want to know if there is a miss or I'm hitting the limiter. I've searched but can't really come up with an actual answer.
Had a full tank of gas. It just seemed like a rev limiter like it was cutting off right there around 5,000-5,500
Will searching I saw some people saying that the l98's are limited at 5200 where it cuts the fuel off. Others say the limiter on them is 6500. So many people saying so many different things. Almost seems like nobody actually knows.
I have a supercharged 383 that easilly revs past 6,000 rpm, I accidently went over 6,000 rpm when running it in in the first hour of it's life.
I actually have no need to test the rpm limits as the h/p and torque is available from idle with the blower.
Would an ignition control module under the cap and rotor cause this? Just shooting from the hip here. New to the car scene.
Unless your attempting to go outside box like down shifting into second at 75MPH.
Its up to u to figure if thats even whats going on and or which one.
Pulling the vacuum line on the reg should get ya 40psi and it will run rich and may make ur motor pull harder, if you don't mind cleaning plugs under anything but maybe full throttle.
I'd say u need to run a full can or 2 of Injector clean hooked up on the rails with the pump line pinched or shut off and put ur wires off of any head or manifolds or maybe move them around in the dark along with some fresh plugs and filters if u haven't done so lately
Also the firing order always needs to be straightened out on all 1975 to 1991 V-8's It's 1-8-4-3-5-6-7-2 Cly #'s 4,& 3 and really 5 & 6 need to never cross or touch from the dist to the spark plugs
It will/can cause a mid to upper rpm breakup,miss fire not really when the wires r new but when they get a little older and kinda dry out
So thats what I would be doing or have done
Doesn't matter teh exact number though; that your car runs good up to high RPM/WOT indicates that you have good pressure in normal driving...when you have the gauge on it, it shouldn't drop or waver at all as you climb through the RPM range at WOT. If it does, you have a problem.
Pumps can and do fail in a wide variety of ways; like a "switch", losing pressure under heavy load, making a lot of noise, etc.
If your pressure is what it should be in normal driving or idle, then "fades" under high demand, that is pump, filter, sock etc. -The FPR would be working fine. if the FPR has gone bad, your pressure issue would be constant and present under most if not all operating conditions.
The problem you're describing only occurs under WOT/high RPM, so it's very unlikely that it's a regulator.
personally I'd be a little concerned if my fuel pressure was sitting at 32, rather than the higher end of the spectrum.
Also I agree with Tom's analysis.
Took it for a drive and it still missed around 5,000 but it isn't missing as bad. It misses but I can still feel the power pulling though instead of just flatlining like before. At least that's what it feels like.
I pulled out the 2 and 4 spark plugs, easiest to get. And the tips are looking lean. These plus are the ones that were in it when I received the car. Haven't changed them yet. Car seems more sluggish since I've been driving it compared to what I remember when I used to drive it years ago before I bought it from my dad a few weeks ago. I took a picture of the plug.
The tip is white if you can't see it in the picture.
So it defiantly seems to be a fuel related problem. Now to find it.
First thing I'd check.
